Drilled Air Filter Cover for High Elevation Riding
Results 1 to 3 of 3
Like Tree2Likes
  • 1 Post By PalmStateCrawler
  • 1 Post By admiral
Thread: Drilled Air Filter Cover for High Elevation Riding
    May 2012
    Tucson, AZ
    976
    So I'm going to be spending a few days riding up around 9000' elevation, and I'm wanting to optimize the performance of my stock jetted 2011 carb. I'm riding up there and back from 2,400' Tucson, so re-jetting is out.
    I'm interested in drilling the holes in the air filter cover as I've read about, but I was wondering if there were any tips as to size, number, and location of holes that folks who've done this mod might have to offer.
    I asked about riding above 9000' a while back and Qwerty suggested drilling "a few 1.25cm holes". I was only spending about an hour at that elevation then, so I didn't drill, but since I'll be "riding high" for a few days this go round I'm ready to commit.
    I was also wondering about alternatives for plugging the holes, it seems tape is pretty popular but I'd love to try something a little more polished if anyone has any suggestions.
    2012 KLR650
    - Sold
    2013 Tiger Explorer XC
    2014 CB500X - RRP L3
    Aug 2011
    Cayce, SC
    3,109
    Uni airbox filter vents. When you dont need them you can tape over them from the underside and no one could tell the difference.
    DonBenito likes this.
    '86 BW80 farkled to size
    '10 TW200 you will be missed
    Frosty Hollow
    13,098
    Here are the holes I drilled into my air-box cover. Right off I don't know what size drill bit I used, but you'll get a good idea. When I cover the holes up a lower elevation, I just use black duck tape. I used some rubber grommet plugs for a while, just found using tape wasn't as noticeable as I first though.
    If I had to drill the holes again, I'd drill them all above the plastic cover exposed area to avoid any water splashing in the lower exposed holes. Think I would drill slightly smaller holes as well.
    I found the holes help a lot with power and making starting easier at elevation, but I still have to turn the idle adjust knob slightly.
  1. Replies: 3
    Last Post: 03-16-2013, 08:08 AM
  2. Oil Filter Cover O-Rings
    Last Post: 09-19-2012, 05:38 AM
  3. Oil filter cover leaking
    By junk munk in forum General Discussion
    Last Post: 10-25-2011, 12:15 AM
  4. oil filter cover leak
    Last Post: 10-16-2011, 06:55 PM
  5. 2001 Air Filter Cover
    By 1madhonda in forum TW200 Classifieds
    Last Post: 08-18-2011, 05:02 AM
drilling air box high altitude
drilling airbox lid high altitude
drilling holes in airbox lid for higher elevation
