Recommended tire changing tools for travel?
Results 1 to 4 of 4
    Member moresnow's Avatar
    Oct 2012
    Iowa
    75
    Any particular set of spoons etc. that seem better than others? These will be bag mounted on the front fender. I'll have to check the bag length also. Thanks
    Senior Member rm_hm's Avatar
    1,619
    I posted my favorite tire tools in this thread https://tw200forum.com/forum/performa...-x-18-a-2.html Post #7
    And more past threads on tire tools
    https://tw200forum.com/forum/technica...ire-irons.html
    https://tw200forum.com/forum/technica...e-off-rim.html
    The smaller the tire iron the harder they are to use and more likely they will pinch a tube.
    Senior Member Tuber's Avatar
    Sep 2012
    VT
    734
    use really big tie wraps...the kind you can open up without cutting. After you deflate the tire and break the bead, wrap 3-4 tie wraps around your tires, threading thru the rim...pull them up way tight and slip the tire off. remount a new tire the same way...pull the wraps tight to squeeze the sidewalls down. I know quite a few guys who have used this method on street bike tires...helps save your rims too. you can also use straps, the kind without ratchet buckles...see the link
    Mount a Motorcycle Tire Without Using Tools - ADVrider
    Senior Member mattmus4357's Avatar
    Oct 2012
    NW Arkansas
    250
    I carry three of these Tusk lightweight tire irons with me. I've used them a few times and they do a good job. Definitely handy to have on the bike during long rides since they're light and small.
    Tusk Ultra Lite Tire Iron | UTV | Rocky Mountain ATV/MC
  1. Travel Tools
    By josh42177 in forum Technical Help
    Last Post: 03-14-2015, 01:16 PM
  2. Light weight travel
    By r80rt in forum General Discussion
    Last Post: 01-15-2013, 08:15 AM
  3. Tools
    By Polarpilot in forum General Discussion
    Last Post: 03-10-2012, 08:53 AM
  4. What kind of oil is recommended?
    By Beewerks in forum Technical Help
    Last Post: 07-24-2011, 08:48 PM
  5. Which Tools To Buy?
    By thumper in forum General Discussion
    Last Post: 02-10-2011, 01:41 PM
front fender tool
recommended tools for changing rv tire
tire iron
