Oil in Magneto Case
Results 1 to 3 of 3
    Junior Member TWAlan's Avatar
    Oct 2010
    4
    I just picked up a 1987 TW and went to check the ignition timing. When I removed the timing cover (plug at top of left case) with the engine idling, the magneto housing was pressurized and oil mist was blowing out of the inspection port. I pulled the left case cover and it was full of oil. Is the magneto/starter compartment supposed to be wet or dry? If it's supposed to be dry, then I guess I have a bad crank seal... Comments? Thanks for your help!
    Senior Member Sly Fox's Avatar
    Oct 2010
    Wiltshire, UK
    203
    Don't panic! It is a wet one.
    We're in 'Bat Country' now....
    Oct 2010
    4
    Quote Originally Posted by Sly Fox View Post
    Thanks!
    Now I just have to figure out why my T Dub has an intermittent idles fine -miss-backfire-run-well-then-horribly problem...
    I think it's the dreaded intermittent CDI problem... Ugh!
  1. Carrying case?
    By Woodi23 in forum General Discussion
    Last Post: 09-17-2012, 10:57 AM
  2. Grease in Magneto (?)
    By msmiller in forum Technical Help
    Last Post: 09-07-2012, 08:13 PM
  3. Oil being pushed out the crank case
    By okarmygrunt in forum Technical Help
    Last Post: 04-15-2012, 08:21 PM
  4. TTR Case Bolted to A TW Case
    By ronnydog in forum Performance and Customization
    Last Post: 10-29-2011, 06:03 AM
  5. New Pelican Case
    By Larry in forum Performance and Customization
    Last Post: 04-21-2011, 08:09 AM
is the magneto of tw200 wet or dry
oil in magneto case
oil in magneto compartment
tw200 oil on magneto
