Chains/sprockets
Results 1 to 10 of 13
    Junior Member Penerka's Avatar
    Aug 2010
    Colorado
    10
    OK, I've read all the info regarding changing out my chain to an o-ring chain. Where do I get one? How much should one cost? Since the majority of my riding will be on the street, which sprocket should I get. (thinking the 47 tooth would be good). I have a 2008 TW and love it. Had it about 4 months and hardly ride my street bike anymore. In fact, it is for sale. I put on the Stearns seat cover from WalMart, what a difference. Thanks for all of the info. Ride safe.
    Senior Member Dark Sol's Avatar
    424
    Sprocket depends on where you live and how much off roading you want to do. I've only tried 50T and 44T, but from what I hear 47T is a good compromise for somebody that's like 60+% street and 40% off road. You would not want to climb steep hills with anything lower than stock, but for just cruising or easy riding on offroad trails 47 should be fine.
    If you wanna go to 44 you'll drop another 400+ on the engine speed, which makes cruising at 45 mph nice and smooth, the bike's optimal cruise speed. 50 is alright, 55 gets up there and 60+ is pretty fast, but thankfully 1k lower than stock. Only problem with this gearing is the lack of 5th gear power, it feels almost useless and if you go up on any kind of hills - forget about it. Other than that and take offs needing a bit more power, 44T is pretty good for the street.
    If you wanna go with 47 and you don't mind taking the engine cover off, you might wanna try 15 up front for 15/50 instead. It's a just barely a little bit taller of a gearing than 14/47 but I've heard many great things about it too, plus a bigger front sprocket is supposed to be better on the drive and the chain. If you think you'd rather go for 44, might wanna consider 15/47 too for the same reasons, same gearing as 44.
    2008 CRF230L
    2006 CBR1000RR
    2007 CB919 - 70k Miles and still runs like new!
    * 2001 TW200 (Sold after 15k miles of fun)
    Senior Member darnold87's Avatar
    Salem, OR
    908
    From what you said, I suggest the 14/47 combo. (I prefer 14/50 for town and trails, 14/47 is nice for street/hwy)
    I went with LytleRacing. It was something like $110 shipped for front sprocket, rear sprocket, 130-link DID o-ring chain, and 2 extra masterlinks. I got a great chain tool at the local tami dealer for $20. so I could choose my desired chain length.
    Good luck!
    ~Davey
    '89 TW200
    '94 Suzuki Sidekick
    Senior Member wrench-puller's Avatar
    Ladysmith, B.C.
    549
    Hi, I just changed my 2009 over to a 47T and O-ring chain. I felt no need to change the front sprocket as the 14/47 gave me what i needed which was just to lower the RPM on the highway but still have trail ability. The o-ring chain is a must as it gives you longer time between adjustments and because it doesnt sag every ride like the stock, shifts are smooth and crisp due to the tension staying put. Just yesterday the wife and I when for a ride out to search for firewood in the back country. The 47T allows us to do 100 Km/h on the highway, but still climb the hills and through washouts with no problem with both of us on it! I love my bike to death and although the 50T stock was nice, the 47T is a real + to the ride-ability. As for where to buy it, I am in canada and found the cheapest place for both sprocket and chain was at our local Yamaha dealer (even being after market parts).The DID chain was even cheaper then Ebay and arrived faster.
    So I highly recommend doing the 47T with the chain, but if you have a high milelage front sprocket you should consider changing it out at this time too. Best of luck and ride safe, Chris.
    2009 TW200, Jimbo shield, 47&55T rear with DID chain, Maxxis Ceros Rear, Kendra 270 front, extended swing arm, 1"Risers, Rear rack, Raised front fender, XOG GPS.
    918
    My experience says go with the 14/47 or 15/50, but NOT the 14/44 or 15/47.
    Sold bike.
    Salem, OR
    908
    I missed the 14/50 setup when I went to 14/47... The first steep loose trail I did was a killer and i was burning the clutch.
    This lead me to do the dual sprocket setup... sooooooo nice.
    ~Davey
    '89 TW200
    '94 Suzuki Sidekick
    Nov 2010
    Frostbite Falls Ill
    2,719
    I run 203 and 204 bridgestones since most of my miles are on pavement. When I changed rubber, I also changed ratios.
    I weigh 270 and a 14X49 works well for me
    Phelonius
    Phelonius
    14/54 Use on pavement at high altitudes where the engine won't pull 5th gear, anyway. 1st is useless on pavement, but very hand for engine braking on steep, rough downhills. Closes up the perceived gaps between gears. My choice for offroad riding, especially in steep terrain at high altitudes.
    14/50 and 15/54 Good all-around ratios. No problems in rough terrain or 500-700 mile days on the highway.
    14/47 and 15/50 Good for general street riding and easy dirt. 1st becomes functional from stoplights. Less vibration at speed. Best overall fuel economy.
    14/44 and 15/47 good for long downhills with high speed limits. 85mph possible. You'll be climbing these hills in 4th gear at 55mph, so no real loss there, lots of downshifting on hills on the highway. The 3-4 and 4-5 gaps become problematic, as in the bike will run 65mph in 4th, then shift to 5th and the engine won't maintain 65. Oddly, hit the same stretch of road at 70 in 5th, and the bike will maintain 70. Lowest vibration at speed. Easier to ride in city traffic because gaps between lower gears are wider resulting in less shifting with changing traffic speeds. Useless on any but the easiest offroad. Tough on the clutch, important since the TW clutch has 1 less plate than other bikes of this engine family.
    Senior Member rmartin's Avatar
    Quartzsite, AZ/ Hoopeston, IL
    392
    So if I were to order an o ring chain for the stock 2009 tw200, how many links should I order?
    Are there different manufacturers of the chain?
    I will be getting a used one next week with about 400 miles, and I thought I would get it right away, and keep the old one for my other tw that has 5300 miles on it.
    Quote Originally Posted by rmartin View Post
    Same link count as you already have will fit. 122 for 14/50. Problem is, I don't know of anyone who sells a 122 at a reasonable price--seems they all want to charge $$$ for cutting the chain for you. You can buy a chain breaker on sale cheaper than the upcharge for custom cut chain. Crazy!
  1. motorcycle snow chains
    By mudpuppy in forum Performance and Customization
    Last Post: 04-01-2014, 01:36 PM
  2. 428 o-ring chains on e-bay
    By goldenhtr in forum General Discussion
    Last Post: 09-19-2012, 03:13 PM
  3. *Sold Out* BEST DEAL ON DID O-RING CHAINS EVER!!!!
    By PalmStateCrawler in forum Performance and Customization
    Last Post: 07-31-2012, 07:52 PM
  4. sprockets and chains
    By YTWTX in forum Technical Help
    Last Post: 04-10-2012, 09:24 PM
  5. Colored chains
    By PalmStateCrawler in forum General Discussion
    Last Post: 11-02-2011, 10:34 AM
