valve inspection cover o-ring
Results 1 to 5 of 5
    Senior Member thumper's Avatar
    Oct 2010
    232
    Is there anything special about these darn things that they cost $7 bucks each?
    I was going to order a couple yamaha ones then try to match them up with some from the automotive shop
    or the hardware store.
    Does it have to be a special rubber or something since its on a hot motor?
    Thanks for any guidance.
    Igofar
    BC
    623
    Quote Originally Posted by igofar View Post
    Igofar
    I replaced mine with some that I got from a Plumbing Supply store...$0.60 each and they work fine, no seepage or leaking whatsoever.
    Go for neoprene instead of rubber if you have the choice.
    2008 TW200
    Southwest corner of BC Canada
    Senior Member BillMichaels's Avatar
    SF Bay Area
    277
    When I change the oil I place all the o-rings in a cup of PB Blaster and let them soak. Their label reads "PB restores life to "O" rings and rubber seals." It's worked for me.
    **Igofar & Elime: PM me so we can meet for eats and I'll let you try my avatar tip**
    1998 HD FLHTC
    2004 TW200
    2004 TW200
    BC
    623
    Quote Originally Posted by TW_in_BC View Post
    I should also add: Do NOT overtighten the bolts that hold the covers in place! The threads in there are made of butter or something equally soft and they strip VERY easily!
    2008 TW200
    go to any industrial seal place and match them up. I've used several different materials and they all start leaking after 5-6000 miles because the heat makes them take a set. I bought 20 sets for about $25 and figure I have a lifetime supply.
  1. what do you use on your O ring chain
    By aladdin in forum General Discussion
    Last Post: 05-30-2012, 03:48 PM
  2. Oil Filter inspection
    By Hoogie514 in forum General Discussion
    Last Post: 01-16-2012, 07:35 AM
  3. Valve Cover Gasket
    Last Post: 10-25-2011, 12:53 AM
  4. valve adjusters: intake valve died, who fights next?
    By jontow in forum Technical Help
    Last Post: 07-14-2011, 10:24 PM
  5. Standard vs. O ring vs. X Ring Chain
    By Fishman393 in forum General Discussion
    Last Post: 05-14-2011, 05:46 PM
yamaha tw200 valve cover o ring
