Carburtetor hesitation
Results 1 to 5 of 5
    Junior Member Alfdude1's Avatar
    Nov 2010
    4
    Greetings,
    I am working on a 1996 TW200 and have been thru the carb several times. The bike will idle and rev up if gently rolling on the throttle, BUT if you snap the throttle open, it dies! I know this carb does not have an accelerator pump, but if id t did, it acts like it is not working. I have a new square ring on order for the main jet assembly because the old one was brittle and cracked. Any ideas of what would cause this biek to up and dies if the throttle is snap open? If you snap it open and then close it real fast, it will pick back up and run.
    Thanks,
    Alf
    Desert, SoCal
    7,369
    Since you say you've been through the carb several times, try loosening your gas cap and see if the problem goes away. Gas cap vents can clog causing fuel starvation.
    Check your ACTUAL float level using the clear tube method rather than the manual's 1.2" static setting.
    It's a PITA, but my TW's with the older carb starve at the recomended settings.
    Nov 2010
    4
    I have the fuel level at the recommended 7.5 - 8.5mm below the carb base. It idles great and runs well, UNTIL you snap the throttle open.
    Alf
    Senior Member thumper's Avatar
    Oct 2010
    232
    Quote Originally Posted by Alfdude View Post
    Alf
    My 2008 started doing the same thing for a while. I ran some sea foam through her and she started running great after approx half a tank of gas. My guess would be the holes in the jets are getting dirty, or the brass material itself is wearing. I believe elime posted a thread a while back about that, and posted some really good up close micro photos of it.
    All I know is the sea foam worked for me (and I thought my carb was sqeaky clean too)
    Hope this helps.
    An engine that simply dies when the throttle is whacked is running lean. Try opening the pilot screw. Check for vacuum leaks.
  1. WOT hesitation or subtle bog
    By RockyTFS in forum Technical Help
    Last Post: 09-22-2012, 01:37 PM
  2. Hesitation with acceleration
    By surferguy in forum Technical Help
    Last Post: 10-05-2011, 04:29 PM
  3. Miss, Backfire, Hesitation ***Fixed!***
    By pantera1 in forum Technical Help
    Last Post: 06-16-2011, 04:50 AM
  4. Wanted to Say Hi. Bought 2, engine hesitation on 1
    By Snake2715 in forum General Discussion
    Last Post: 09-13-2010, 08:36 AM
tw200 hesitation off idle
tw200 hesitation on acceleration
