Speedometer broken?
Results 1 to 5 of 5
    Senior Member Henrici's Avatar
    Sep 2010
    Big Island, HI
    180
    Hello I was driving the other day and my speedometer stopped working. Is this a common problem for these bikes? Is there an easy fix? Thanks in advance for any help!
    1996 TW200 Edmonton, AB
    590
    Check first the speedometer cable isn't broken.
    Sep 2010
    Big Island, HI
    180
    Quote Originally Posted by PJungnitsch View Post
    The cable appears intact.
    Verify correct cable. The wire may be too short even if the sheath is the correct length and has the correct ferrules on both ends.
    Hook the cable to the wheel, disconnect from the speedo, spin the wheel, and make sure it is turning. If so, dosconnect from wheel and hook to speedo, and give the wheel end a hard twist between you fingers to see if speedo works. If no, wouldn't hurt to try to take the speedo apart and figure it out. Speedos hardly ever break.
    Sep 2010
    Big Island, HI
    180
    Well I pulled the speedo cable off and the cord was snapped about two inches above where it connects to the wheel. Apparently the new 45 tooth sprocket was just to beast for the speedometer cable to handle hahaha
  1. Broken 91
    By arrowsmith in forum General Discussion
    Last Post: 05-15-2013, 02:52 PM
  2. Broken Vet's doing ok.
    By Xracer in forum Off-Topic
    Last Post: 04-11-2013, 08:36 AM
  3. Bleed valve broken
    By RodneyBR in forum Technical Help
    Last Post: 08-26-2011, 08:08 AM
  4. Broken Vets doing OK.
    Last Post: 08-03-2011, 08:11 AM
  5. Frame is broken on my 89
    By Dave Nafziger in forum Technical Help
    Last Post: 05-31-2011, 02:47 PM
how to fix speedometer on tw200
how to take apart yamaha tw200 speedo
