LED / HID Lighting
Page 1 of 5 123 ... LastLast
Results 1 to 10 of 42
Like Tree1Likes
Thread: LED / HID Lighting
    Senior Member Henrici's Avatar
    Sep 2010
    Big Island, HI
    180
    I ride at night frequently and would like to increase my ability to see and be seen. I would like to know if anyone has experience installing LED turn signals and/or brake lights and what I would need to install a set on my bike. Do I need to modify my electrical system? or is it just plug and play? I see many LED turn signal kits available, so any tips on what I should be looking for or trying to avoid would be greatly appreciated!
    Also has anyone installed a HID headlight on one of these bikes? Any thoughts on the feasibility of this?
    Thanks for your time.
    -Tony
    Tdub is all LED/HID, even the gauge and indicator lights. I bought the LEDs from superbrightleds.com and the HID off ebay.
    I tried the 90* 1156 and 1157 replacements in the turns, but vibration killed the 1156s in just a few miles. I switched to the flat 36LED panels and glued them into the housings with a bit of silicon glue. The 1157s are still good. I have the 5W Luxeon in the tail light. Get the brightest bulb you can for the brake/tail. The Luxeon is brighter than stock. The multi-LEd indicator bulbs are too bright. Use the cheaper single LED versions.
    The only change I made other than bulbs is a flasher for LEDs. Just carry the old one into any auto parts store and ask for an electronic replacement that is not load sensitive.
    The HID is half a bi-xenon kit, for a car or truck, the other half of the kit is on my CB550.
    Sep 2010
    Big Island, HI
    180
    Thanks for the info!
    So was there any mounting issues you had when installing the HID headlight?
    Quote Originally Posted by Henrici View Post
    Not on the TW. The HIDs I used were a conversion kit for H4 bulbs. The 2001 and newer TWs already have an H4 bulb, so it was pretty much as easy as replacing the stock bulb. Wiring a headlight relay for the transformer through a rocker switch mounted on the handlebars wasn't too difficult.
    On the CB, I bought an H4 conversion headlight bulb to fit the stock headlight housing. Wiring was the same as the TW.
    Senior Member mudpuppy's Avatar
    NW Illinois
    144
    The current Motorcycle Consumer News magazine likes these small, LED based, off-road driving lights--- a little pricey, but they supposedly have very little current draw, a big light output, and are designed to stand up to the rigors of off-roading (including waterproof, metal construction). Details and videos are here : http://www.twistedth...oductview/5224/
    They are adapted specifically for cycle mounting from the Solstice brand's Vision X LED off-road lights (which at about $120 per light, plus the mountings/switches/wiring pretty much equals the Twisted Throttle Denali light kit): http://scripts.twist...rticle/view/312
    A univeral mounting kit is included, and bike specific ones are available (I didn't see a TW listed). MCN sucessfully mounted some to the front reflector mounting points on a DR650, so that would be one possiblility for TWs, as are turn signal mounting points.
    Corey
    two 2009 TWs, Ricochet skidplates, Moose Racing 'Expedition' rack (like a Borrega), DID 428V O-ring chains, DMoto2 -style black steel footpegs from eBay
    Sep 2010
    Big Island, HI
    180
    wow that's great I think I'm gonna start off with the hid....
    Sep 2010
    Big Island, HI
    180
    Quote Originally Posted by mudpuppy View Post
    Corey
    Thanks those lights look pretty sweet.
    Stupid high prices.
    Sep 2010
    Big Island, HI
    180
    yeah I think I'm gonna start with the HID and see how that one works... Those lights do look like they would be pretty cool tho. Probably wouldn't consider picking a set up unless you could get them for under $100....
    Junior Member jasonck08's Avatar
    Nov 2010
    6
    Do not install an HID in the stock TW200 light housing. It's dangerous for oncoming vetches and is illegal. a 35W HID is going to be 2-3x the brightness of the stock bulb. HID light behaves differently and needs special optics in order to be safe for road use.
    txarsoncop likes this.
  1. LED Lighting
    By liquidsilver in forum Performance and Customization
    Last Post: 07-21-2013, 04:33 PM
  2. led accent lighting
    By PalmStateCrawler in forum Off-Topic
    Last Post: 11-06-2011, 06:07 PM
  3. hid lighting
    By dizzle2 in forum Performance and Customization
    Last Post: 06-24-2011, 11:56 PM
  4. LED lighting
    By chevyluver in forum Technical Help
    Last Post: 01-08-2011, 12:19 PM
  5. Auxillliary Lighting
    By bigdreama in forum General Discussion
    Last Post: 09-18-2010, 01:12 PM
hid on tw200
tw 200 best hid
tw200 forum led light
tw200 headlight upgrade
tw200 hid bikemaster
tw200 hid headlight
tw200 light kit
tw200 light relay kit
yamaha tw 200 hid bulb
yamaha tw200 hid headlights
yamaha tw200 hid lights
yamaha tw200 led headlight kit
