Sputtering on washboard and large bumps
Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Like Tree1Likes
Thread: Sputtering on washboard and large bumps
    Ephrata, WA
    1,125
    My bike runs great. Its a little hard to start with the electric starter but starts on the first kick. Anyways, my bike sputters and loses power when I go over washboarded or hard rock-packed roads and large bumps. It loses power and then after the washboard area it comes back to life again. I know that there could be a million possible causes, but I was curious if anyone could shed some light on the subject. I know that its NOT my kick stand switch. I have good gas in it and all my fuel connections are tight. I have read about the gas cap vent. Does anyone actually know where it vents from? I do have a tank bag strapped tightly to my tank and it covers the cap. Could this be the problem? The weather hasn't allowed me to go out and test it without the bag yet. Thanks.
    1990 TW200
    Desert, SoCal
    7,369
    Just loosen the cap and ride it. If the problem goes away your vent is clogged.
    As you said, this could be a lot of things, but since you say it only happens on washboard roads I'd take a look at wiring first. Loose connectors, bare or broken wires, particularly near where they enter the left side cover and where they pass through the frame before going under the seat, and all the CDI connectors under the right panel.
    1996 TW200 Edmonton, AB
    590
    Might want to look under the tank at the coil connections as well. Just for maintenance I'm slowly taking all my electrical connections apart, shining them up with sandpaper or a file, coating them with a bit of Vaseline or dielectric grease, and then making sure they go tightly back together.
    Senior Member jbfla's Avatar
    FL. GA, NC
    2,396
    My guess is that it is not the gas cap vent. If it were, your bike would not start running good again after the bumps. When you open the gas cap, you would hear a whoosh as the air rushes into the tank.
    Possible cause: most likely, loose connection, intermittent electrical/ignition problem caused by the bumps.
    Less likely,... a fuel problem. The main jet may not pick up fuel from the float bowl due to a low fuel level, dirt in the bottom of the bowl, and sloshing around of fuel due to the bumps. I am skeptical that all these conditions would happen every single time you hit the washboards but it's a possibility.
    jb
    Nov 2010
    Frostbite Falls Ill
    2,719
    I used to have that problem on two stroke twins about 40 years ago. I thought maybe better carbs had eliminated it.
    Phelonius
    Phelonius
    Ephrata, WA
    1,125
    Thanks for the replies. I'm thinking loose connections as well. I'll dig into it when I get some time. Any further help would be appreciated.
    1990 TW200
    Senior Member thumper's Avatar
    Oct 2010
    232
    Quote Originally Posted by Rainman View Post
    I went for a ride today on a really bumpy, tree root, pot holed type road. After I hit several large bumps the bike died and coasted to a stop. I tried to start it and it just kept cranking. I had gas, spark, etc.
    I opened the gas tank and got the whooosh sound! Started right up. I'm thinking the warm day, and all the bumping caused the gas tank to swell a little or the vent got clogged. either way, removing the cap fixed it.
    Nov 2010
    Frostbite Falls Ill
    2,719
    So I guess you are saying your gas tank sucks?
    Why do you suppose the malady manifests itself when going over bumps?
    Phelonius
    Phelonius
    Oct 2010
    232
    Quote Originally Posted by phelonius View Post
    Phelonius
    no comment
    Senior Member Gerry's Avatar
    Paradise, Calif.
    3,513
    This is not a lewd joke, but are you sure your tank was sucking and not blowing? As I read your 'problem' the symptoms reminded me of how my Dunebuggy acted when I had the floats on carbs adjusted to high. Now, should the fuel be under the slightest amount of pressure, the situation would be even worse as fuel may be 'pushed' pass a partially seated needle. Just a thought cause the buggy (VW) ran very rough (flooding) when on rought surfaces until I (yet again) reset the float height. I have since read that the Weber ICT's were very sensitive. Gerry
    Take care my Friend.........
  1. Large mileage - what bits will need changing.
    By UKJ in forum Technical Help
    Last Post: 04-23-2013, 03:03 AM
  2. LARGE storage tubes
    By Ripshod in forum Performance and Customization
    Last Post: 04-27-2011, 12:19 AM
  3. Can this bike handle a large man?
    By toddler83 in forum General Discussion
    Last Post: 01-10-2011, 12:14 PM
  4. Sputtering Problem?
    By thumper in forum Technical Help
    Last Post: 12-05-2010, 08:32 PM
  5. Large rear sprocket needed
    By Zukman in forum Technical Help
    Last Post: 09-05-2010, 10:29 PM
2011 sportster sputters over bumps
tw200 sputters when you first gas it
