Cost for fork seal replacement?
Results 1 to 10 of 15
Like Tree1Likes
Thread: Cost for fork seal replacement?
    1993 TW200 in Meridian, Idaho
    1,533
    I have a leaking fork seal on my '93 TW and now that the weather has me riding less often, have decided to get it taken care of. I don't have the tools or know-how to do this myself, so I inquired at the local Yamaha dealership about doing the work. I had them quote seal replacement for both forks (figure if I only do the one the other will go soon) and also new fork boots as the ones I have are shot. The estimate was $225.00 This seems a bit steep to me (and putting that in a bike that only cost me $1,400 total hurts even more.) Do you think this estimate is excessive? Any other thoughts about how to get this job done "on the cheap."
    Member Mexicant's Avatar
    Nov 2010
    37
    That sounds kinda high to me, but I'm cheap. I recently replaced the fork seals on one of the streetbikes in the stable. Total cost was about $40 for the fork seals and fork oil. It took me about an hour to do, maybe less and that was taking fairings off and more involved than the TW would be. Check these links and get an idea of what's involved, you may want to tackle it yourself and keep some money in your pocket.
    http://www.motorcycle.com/how-to/how...eals-3442.html
    http://www.motorcyclecruiser.com/tec...als/index.html
    http://www.motorcyclistonline.com/ho...als/index.html
    Member shadow's Avatar
    Sep 2010
    Boise, Idaho
    92
    We need to get together as mine need swapped to if we can find someone who knows how. I had a set done on my Ducati for $125 labor at Big Twin but I pulled the forks off the bike first. Was your quote with the bike or just the forks?
    Junior Member imnxnyr's Avatar
    Oct 2010
    16
    http://www.youtube.com/watch?v=Y43k1qFVGW4
    This link gives a basic understanding to fork seal replacement if you're gonna do it yourself.
    there is a part 2 for this also.
    Member dalsco's Avatar
    78
    Its the new boots they run about 50 bucks a piece!!!
    78
    plus about 15 bucks per seal and about 20 for oil= 50 for parts plus the 100 for boots and 75 for an hour of labor there is your $225..... sorry its right as rediculous as it seems. do it your self and save the 75 dollars of labor or forget the boots and save the 100 bucks and have them do it......
    Quote Originally Posted by dalsco View Post
    Or use aftermarket parts instead of OEM, do it yourself, and save $175.
    1,533
    Quote Originally Posted by imnxnyr View Post
    Thanks for the video. It's enough to tell me I don't want to do this myself!
    JClark likes this.
    Senior Member brownie2's Avatar
    Sep 2010
    108
    The boots are the big money item.
    I just changed fork seals for the first time ever. It was actually pretty easy. A forum member here gave me the hint to use a big metric bolt welded to a small pipe to hold the inside so the allen bolt could be removed.
    I also changed the metal slides (something I wouldn't do again unless the copper is showing like an engine bearing). I ended up cutting them out with a dremel since the local shop failed to remove them for me and they had the proper puller.
    Nov 2010
    37
    Are the fork boots that expensive?! I saw these listed, maybe it's the wrong ones?
    http://www.rockymountainatvmc.com/pr...lVehParts=true
  1. What is needed for Fork Seal replacement?
    By glas482 in forum Technical Help
    Last Post: 11-13-2016, 06:40 PM
  2. Fork oil seal replacement
    By canadainshiver in forum Technical Help
    Last Post: 03-02-2013, 07:55 PM
  3. Beginner's Guide to Fork seal replacement
    By B-dub in forum Technical Write-Ups
    Last Post: 08-08-2012, 06:37 AM
  4. Fork Seal Replacement?'s
    By brownie2 in forum Technical Help
    Last Post: 11-08-2010, 07:08 PM
  5. Front Fork - Seal Replacement
    By FnMag in forum Technical Help
    Last Post: 09-28-2010, 05:49 PM
cost fork seal replace
fork tube seal replacement cost
how do you pull front fork seals on a yamaha tw200
how to replace a fork seal on 1991 yamaha tw 200
tw 200 fork seals
tw200 fork oil seal number
tw200 fork rebuild
tw200 fork seal replacement
tw200 fork seals
tw200 valve seal replacement cost by yamaha dealership
tw200 yamaha fork oil replacement
yamaha tw fork seals
