valve adjusting tool
Results 1 to 10 of 10
    Nov 2010
    Frostbite Falls Ill
    2,719
    The other topic was locked so I'll post this way. I have made the tool two different ways. One is to braze a square socket screw onto a steel rod.
    The other is to get a piece of steel, (I used an old screw driver), and cut a slot in the end with a dremel tool to make a small open end wrench.
    It is best to cut it at a slight diagonal so that by turning the tool over you have a different angle of grab. Cut the slot under sized and carefully file to fit with a jewelers file.
    I also use a small (i/8th inch ) number stamp kit to stamp the cleaances inside the rocker cover so that it is always there when you work.
    Phelonius
    Phelonius
    Member bluedevilfootballman's Avatar
    Aug 2010
    88
    pictures please.
    Member dalsco's Avatar
    78
    +1 for pictures!
    Ignition point pliers (really small set of channel locks) and a box wrench.
    Senior Member brownie2's Avatar
    Sep 2010
    108
    Use a square drive deck scew clamped in your needle nose vise grip pliers that should be in your bikes tool pack anyway.
    Your tool design would be small and compact though.
    Deck screw with the threads wrapped with duct tape or screwed into a short piece of wood dowel or shoved into a piece of fuel line. All handle options work.
    Aug 2010
    88
    anyone notice you can actually use your fingers to move the adjusters?
    Quote Originally Posted by tanner View Post
    Yup, but it's hard to hold the adjusters in place while tightening the lock nut.
    Aug 2010
    88
    i usually don't have a problem of my adjusters moving with the lock nut. i always recheck the clearance after tightening the locknut... this reminds me that i need to do an adjustment, i'm having a little excess upperend noise.
    Senior Member christddel's Avatar
    Oct 2010
    Belgium
    376
    I use this tool ... practical and easy
  1. Valve Adjusting Tool
    By Dwight in forum Technical Help
    Last Post: 09-06-2016, 05:34 PM
  2. Valve Adjusting
    Last Post: 04-15-2016, 09:44 PM
  3. Valve Adjusting Some More
    Last Post: 05-05-2013, 07:54 AM
  4. Valve Adjusting Screws
    Last Post: 03-10-2013, 07:29 PM
  5. Adjusting the Valve Clearance
    By vuldub in forum Technical Write-Ups
    Last Post: 09-01-2010, 07:45 AM
tw200 valve tool
