Rubber Plug inside Carb Help Please! QWERTY??
Results 1 to 10 of 16
    Member Quicksand's Avatar
    Aug 2010
    Fort Smith, AR
    30
    After cleaning previously on carb I lost the rubber plug that goes inside the carb and it covers something right by the main jet and the pilot jet. So the question is does that plug play a role and cause problems if not there? Also, can you buy an o ring from a parts store for the pilot set screw, it is almost cracked into. I assume that may be why I am having starting problems.
    Senior Member jbfla's Avatar
    FL. GA, NC
    2,396
    Quote Originally Posted by Quicksand View Post
    ... So the question is does that plug play a role and cause problems if not there?...
    Hope you don't mind if I'm not Qwerty.
    That rubber plug covers a fuel pick up tube for the choke. There is another fuel pick up tube for the choke right next to it.
    I don't know why one is covered by a rubber plug. And I would be more than curious to know if the carb would still work properly without the plug.
    BTW, the plug is about $5.00 plus shipping, depending where you purchase it. I'm thinking a creative mind could find a way to plug that hole without spending $5.
    I have looked at Lowe's, Home Depot, and Ace Hardware for an o-ring that small without any luck. Maybe a specialty parts supplier may have one.
    Maybe McMaster-Carr or Small Parts.
    http://www.mcmaster.com
    http://www.smallparts.com/
    jb
    Member Babaganoush's Avatar
    Aug 2010
    South Central Pennsylvania
    78
    That's a beautiful 'pro' photo of the carb jb and nice labels too! VWD
    Dave
    Nov 2010
    Frostbite Falls Ill
    2,719
    Use a hole punch of the correct size to cut a plug from a piece of neoprene if you have some.
    Brass tubing at hobby shops is available in many sizes. Cut a short piece and chuck it into a lathe or drill press chuck.
    As it spins, file it to a cutting edge. It will be good enough to cut a couple of plugs to try out.
    If you want a more permanent tool , use steel.
    Phelonius
    Phelonius
    Senior Member Gerry's Avatar
    Paradise, Calif.
    3,513
    I have some neoprene and also a punch set... give me an O.D. and punch one out and drop it in the mail. Gerry
    PS.. I have made a punch on the 'qt' from a socket. I place an extention on the socket. This allows me to carefully turn the OD lip against a fine grinding wheel. I am able to put a nice edge on the lip of the socket. For me, this has never weakened the socket for it's intended use, yet is certainly robust enough to punch thru tuff material. On many sockets, the facets seem to have a slight taper and recess and for me, are not reproduce in the stamping.
    Take care my Friend.........
    FL. GA, NC
    2,396
    The rubber plug is a hair over 7mm in diameter (6mm on tapered end), 4mm thick, and slightly tapered.
    The hole it goes into is exactly 7mm. It's a very tight fit.
    The only way I was able to remove the plug was by blowing compressed air into one of the carb holes (I don't remember which one). And if you aren't paying attention, that rubber plug will go flying, never to be seen again.
    jb
    Aug 2010
    Fort Smith, AR
    30
    JBFLA,
    Thank you for the info. I think I might have found the plug. Does it look like a T with the top just a little bit wider than the rest of the plug. What I have is solid rubber about 1/4" long and a little flange around the top to make it seal up inside the hole I suppose. I put it in there and it will fit if I press the edges down inside. If we have a side view of it I would know. I will try to get a picture on here to make sure.
    Aug 2010
    Fort Smith, AR
    30
    JBFLA,
    You were posting as I was typing. What I have doesn't look like that and from what I can tell it will touch the fuel pickup for the choke. Will that be OK or will it be blocking air somehow?
    FL. GA, NC
    2,396
    JBFLA, ... it will touch the fuel pickup for the choke. Will that be OK or will it be blocking air somehow?
    From what I can tell, without sawing the carb body in half, the 2 choke fuel pickups join together. The one under the plug appears to be completely blocked off by the plug and doesn't do anything.
    I'm not sure why Yamaha plugged up the hole. Maybe that was easier than redesigning the carb.
    The only way to know for sure is to try the carb on the bike, with and without the plug. I would try it myself but my TW is in NC for the winter, and I'm in FL.
    I did remove the carb and bring it with me, to give it a thorough cleaning.
    Edit: the 2 choke fuel pickup tubes do join together. I was able to shine a light down one tube, and see the light through the other one.
    jb
    FL. GA, NC
    2,396
    Quicksand,
    I ordered a bag of o-rings for the pilot screw from McMaster-Carr. I think I will have a few extras. They come in a bag of 100.
    Hopefully I ordered the correct size. If you don't mind waiting until I receive them, I'll send a couple your way. Just PM me your mailing address.
    jb
  1. SOLD...New Iridium DR8EIX inside Moose Trail Plug Holder
    By GlassAnkles in forum TW200 Classifieds
    Last Post: 08-08-2012, 10:33 PM
  2. 1987 carb air fuel screw plug
    By Lido in forum Technical Help
    Last Post: 09-08-2011, 03:32 AM
  3. Thanks Qwerty !! AKA Carb tuning (sorta) 1991 Tdub
    By FnMag in forum Technical Help
    Last Post: 07-23-2011, 12:22 AM
  4. Carb drain plug alternatives
    By kennethshaw in forum Technical Help
    Last Post: 03-17-2011, 01:33 PM
  5. Help with inserting the rear carb rubber into the airbox
    By turborob in forum Technical Help
    Last Post: 10-15-2010, 04:09 AM
1987 carburetor
1987 yamaha excel iii rubber plugs in carb
how do i seal the mikuni carb rubber flange on my 1997 harley softail
rubber carburetor carb carby plug
rubber plug carburetor bowl honda
rubber plug in carburetor
rubber plug inside carb
should the rubber plugs in carburetor fit tight
what is the rubber cap for inside of yamaha outboard carb
yamaha excel carb bowl too tight
yamaha phazer rubber plug inside carburetor
yamaha tw200 choke rubber plug
