Startup Procedure
Results 1 to 5 of 5
    Member Quicksand's Avatar
    Aug 2010
    Fort Smith, AR
    30
    For my DRZ400 here is the Typical start up - gas on, choke on, key on, no throttle, crank with E start. Should fire up immediately. Reduce choke when it starts to run ragged. Is this how most of you guys do it on the TW200. It is getting into the 40's now here and I didn't know if that is how I will need to start it or is that just in cold weather?
    Senior Member 805gregg's Avatar
    Oct 2010
    572
    In southern cal where I live I've found it better with no choke, just turn on the gas and start, let it idle and your good to go.
    Usually she won't get going until you put your tongue in the right spot.
    The cold the weather the more I have to choke her. Too much or too little choke and she won't start. I want to move back to the desert.
    1996 TW200 Edmonton, AB
    590
    Quote Originally Posted by Quicksand View Post
    Yeah, that's it. It may take a couple cranks but usually fires quickly at full choke. Let it warm up for a few seconds, ride off, reducing the choke within the first mile to half and then completely off in another little bit.
    Senior Member Woofhound's Avatar
    Federal Way/Cle Elum Wa.
    369
    I removed the plug over the idle air/fuel screw, opened the screw to about 3 turns open and mine starts in the summer without choke, in 30* weather it requires choke still, but still starts right up and stays running
    2009 WR250R
    2005 V-Strom
    1993 Shadow 1100 with Ural sidecar
    2008 H-D Ultra Classic
    2009 Zuma 125
    2004 Zuma 50
    2000 WR400F
  1. Replies: 2
    Last Post: 03-27-2011, 07:05 PM
how to choke start tw200
how to start tw200
start up yamaha tw200
