2009 not starting
Results 1 to 5 of 5
    Junior Member cordite's Avatar
    22
    Jumped on my 2009 TW, turned the switch, the lights came on, I pressed the starter and there was a snapping sound and everything went dead. No lights or anything. I have charged the battery and the same thing continues to happen. If I wait a while and turn the key back on, the lights will come back on but the process is repeated. Once it snaps everything is dead, the lights go off and the starter never does turn over. Any ideas would be appreciated!
    Senior Member thumper's Avatar
    Oct 2010
    232
    Quote Originally Posted by cordite View Post
    Remove the seat! (2) 10mm bolts underneath. Check to make sure your battery bolt didn't fall out like mine did!
    I had the same symptoms. Bolt was missing, cable bouncing around, arching on frame etc. Be sure to go to a motorcycle shop and get a bolt for the battery (most shops have boxes full) I think they are made from a special metal, not sure if a standard bolt would work?
    Hope this helps.
    Senior Member mudpuppy's Avatar
    NW Illinois
    144
    I had the exact same symptoms on my 2009 after I poured some diluted baking soda / water solution on my battery to neutralize some acid. I unscrewed the battery terminal bolts and cleaned the terminals and battery cable ends. Problem fixed.
    Hope yours is as simple a fix as mine.
    Corey
    two 2009 TWs, Ricochet skidplates, Moose Racing 'Expedition' rack (like a Borrega), DID 428V O-ring chains, DMoto2 -style black steel footpegs from eBay
    22
    Just to close the loop on this old topic and perhaps help someone else, problem turned out to be a bad battery. The lights would come on and the battery tested ok (not under load)and the charger even said it was charged. After I finally figured it out I was talking to a friend who is a pretty good motorcycle mechanic, he said "always suspect the battery when dealing with any electrical issue on a motorcycle". So I learned something.
    Ephrata, WA
    1,125
    Thanks for the follow-up.
    1990 TW200
  1. Hard starting
    By cjnett1 in forum Technical Help
    Last Post: 09-07-2012, 06:51 PM
  2. Having trouble starting
    By papa wheelie in forum Technical Help
    Last Post: 03-26-2012, 01:34 PM
  3. Starting Problems
    By MojoJojo in forum Technical Help
    Last Post: 10-21-2011, 12:02 PM
  4. TW 125 starting problem
    By tw125 in forum Technical Help
    Last Post: 08-01-2011, 01:15 PM
  5. im starting to hate my tw
    By dizzle2 in forum Technical Help
    Last Post: 07-17-2011, 09:02 AM
