Timing chain adjustment help
Results 1 to 8 of 8
Like Tree3Likes
  • 1 Post By fishguy
  • 1 Post By r80rt
  • 1 Post By admiral
Thread: Timing chain adjustment help
    Junior Member kevorwaller's Avatar
    I think i need to adjust my timing chain but ahve never done it before, any help would be much appreciated!
    Junior Member valkrider15's Avatar
    8
    Quote Originally Posted by kevorwaller View Post
    Do you mean adjust the timing or adjust the tensioning on the chain. The second is very easy to do:
    1. Find top dead center (remove 2 covers on the left hand side cover and align the "T" on the flywheel with the mark on the case)
    2. Carefully remove the plastic cap covering the adjuster
    3. Loosen the locknut at the base of the tensioner
    4. Adjust the tension by turning the tensioner (center rod in tensioner should be withing .5mm of being flush with the end of the tensioner)
    4. Tighten Locknut and CAREFULLY replace plastic cover.
    If you need to actually adjust timing then I'd suggest getting yourself the service manual (a good idea anyway). I believe you can find it as a download (do a search).
    Edit: Just look here:
    http://twforumc.tmdhosting610.com/in...epair-manuals/
    Member daddysmut's Avatar
    Apr 2014
    43
    hi, i just did my top end and i'm questioning if i have the cam chain tensioner adjusted correctly for my 1998 tw.
    can you please clarify what this means?
    "4. Adjust the tension by turning the tensioner (center rod in tensioner should be withing .5mm of being flush with the end of the tensioner)"
    Feb 2013
    Missoula, MT
    908
    Quote Originally Posted by daddysmut View Post
    It is a little confusing, at first, especially if the "center rod" has sunk inside the adjustment nut. That's what happens as the tensioner wears. Just screw on the top of the tensioner bolt until the rod re-appears. It's in there somewhere. Adjust so that it sits just 0.020" below the surface of the adjustment nut.
    daddysmut likes this.
    Frosty Hollow
    13,099
    Quote Originally Posted by fishguy View Post
    Is it possible to change the cam chain tensioner from the old style (87-00 years) to the new style cam chain tensioner seen on the 2001 and up TW's?
    My 2005 tensioner attaches to the head via 2 bolts. Looks like a pre-2001 screws into the head.
    Senior Member r80rt's Avatar
    Sep 2011
    2,431
    You'd have to change the cylinder too.
    admiral likes this.
    Frosty Hollow
    13,099
    Thought it would be too easy
    r80rt likes this.
    Apr 2014
    43
    ahhhhhhhhhhhhhh gotcha!!!! ya mines way loose then. many thanks, sir
  1. Cam chain adjustment
    By T Dubble D's in forum Technical Help
    Last Post: 09-23-2012, 10:02 PM
  2. Cam Chain Adjustment
    By Eyesell in forum Technical Help
    Last Post: 07-28-2012, 07:05 PM
  3. timing chain
    By maupin81 in forum Technical Help
    Last Post: 06-19-2011, 05:04 PM
  4. Checking new style timing chain tensioner
    By RockyTFS in forum Technical Help
    Last Post: 05-16-2011, 05:27 AM
  5. timing chain adjustment
    By bluedevilfootballman in forum Technical Help
    Last Post: 08-07-2010, 09:13 PM
1997 tw200 timing chain tension
1997 tw300 cam chain tension
adusting the timing on a 2005 tw200
bw200 cam timing
how to adjust a cam chain on a yamaha tw200
replace timing chain on yamaha tw200
topdeadcentermytw200
tw 200 timingchain adjustment
tw200 timing chain adjustment
tw200 timing chain tension adjustment
yamaha 200 timing chain tensioner adjustment
yamaha bw200 timing chain adjustment
