TW carb jet part#s
Results 1 to 1 of 1
Like Tree18Likes
  • 18 Post By Leisure Time Larry
Thread: TW carb jet part#s
    Jul 2012
    Wet-ern Washington
    1,411
    TW carb jet part#s
    TW Carburetor part/jet numbers:
    MAIN JETS
    288-14343-35-00 = 70
    288-14343-39-00 = 78
    288-14343-40-00 = 80
    288-14343-41-00 = 82
    288-14343-42-00 = 84
    288-14343-43-00 = 86
    288-14343-44-00 = 88
    288-14343-45-00 = 90
    288-14343-46-00 = 92
    288-14343-47-00 = 94
    288-14343-48-00 = 96
    288-14343-49-00 = 98
    288-14343-50-00 = 100
    288-14343-51-00 = 102
    288-14343-52-00 = 104
    288-14343-53-00 = 106
    288-14343-54-00 = 108
    288-14343-55-00 = 110
    288-14343-56-00 = 112
    288-14343-57-00 = 114 (TW 87-00 STOCK 49 USA & CAN)
    288-14343-58-00 = 116
    288-14343-59-00 = 118
    288-14343-60-00 = 120 (XT 600 OPTION)
    288-14355-61-00 = 122
    288-14355-62-00 = 124 [AKA 288-14343-62-00]
    288-14343-63-00 = 125 (TW 01-13 STOCK SOME)(LEAN, GOOD FOR HIGH ALT. >6000’)
    288-14355-63-00 = 126 (TW 01-13 STOCK SOME)(LEAN, GOOD FOR ALT. 4000-6000’)
    288-14355-64-00 = 128 (TW 01-13 OPT, CA MODEL STOCK)(GOOD FOR FUEL ECON)(ALT. <5000’)
    288-14343-65-00 = 130 (TW MOST POPULAR OPT.)(NEUT-RICH, ALT. <4000’)(XT 600 STOCK)
    288-14355-66-00 = 132.5 (RICH, GOOD FOR VERY HIGH TEMPS, LOW ALT)(STOCK IN AUS & S. AFRICA)
    288-14355-67-00 = 134 [AKA 288-14343-67-00]
    288-14343-68-00 = 135
    288-14343-70-00 = 140 (XT 600 OPTION)
    288-14343-73-00 = 146
    288-14329-74-00 = 148
    288-14329-75-00 = 150
    288-14343-76-00 = 152
    288-14329-78-00 = 156 [AKA 288-14343-78-00]
    288-14343-80-00 = 160
    288-14329-81-00 = 162
    288-14329-82-00 = 164
    288-14329-83-00 = 166
    288-14329-84-00 = 168
    288-14329-86-00 = 172
    288-14329-87-00 = 174
    288-14329-88-00 = 176
    PILOT JETS
    5LB-14342-65-00 = 31 (TW 01-13 STOCK)
    5LB-14342-17-00 = 34
    43F-14342-19-00 = 38
    43F-14342-20-00 = 40 (TW 87-00 STOCK)
    30X-14342-21-00 = 42 (XT 350 STOCK)
    43F-14342-24-00 = 48
    Darth, TWilight, VTer and 15 others like this.
    - Leisure Time Larry -
  1. Base Line Carb needle setting, PICS of Carb? 1989 TW200
    By YankeePrepper in forum Technical Help
    Last Post: 04-24-2015, 05:04 AM
  2. Replies: 8
    Last Post: 10-29-2014, 10:14 PM
  3. Replies: 8
    Last Post: 01-08-2014, 05:10 AM
  4. 1987 Carb part identification
    By BBMS in forum Technical Help
    Last Post: 08-05-2011, 04:40 AM
  5. Part number for Carb float bowl drain screw?
    By RadV in forum Technical Help
    Last Post: 09-16-2010, 06:16 PM
