Oil Filter Cover Screws -- An Adventure
Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Like Tree41Likes
Thread: Oil Filter Cover Screws -- An Adventure
    Junior Member Solomoriah's Avatar
    Aug 2010
    25
    SO last week I finally got around to changing my oil. I was a little overdue, but not much. I warmed up the bike, then turned it off and let it set for a while so the now-warm oil could settle back into the crankcase, and then I drained it. No problem, other than the usual requirement that I remove the shifter to get that stupid plug back in.
    I pulled the oil filter and attended to it, but as I was putting the screws back into the cover, the two upper screws (the ones with hex heads) weren't getting tight like they should. Idiot me, I didn't realize what was going on until I broke one off.
    At least it was the short one in back. Heaven help me if I had broken the front bolt... it would have been necessary to tear the engine down almost to its component parts to get at it.
    Thinking back, I recalled that the last time the oil was changed, it wasn't me that did it. My bike developed a base gasket leak last year, right at the beginning of the riding season, and I took it to the dealer I bought it from to have that fixed. I can do my own oil changes, but I know better than to go that far into the engine by myself. They seem to have done a fine job at it, but it took quite a while to get it done because they were backlogged.
    Sitting there with the head of a broken bolt in my hand, a scenario unfolded in my head. The engine work was done by a senior mechanic, I'm sure, as I have not detected any problems with the bike otherwise. A few thousand miles with compromised bolts holding the cylinder together would surely have revealed something. But I realized that the "easy" job of finishing it up was probably passed to a junior mechanic, and that fellow took a large wrench or probably a big ratchet to those puny bolts holding that cover on. Of course, on my 2008 model the lower bolt has an Allen head, so he couldn't use the same tool on it, and that screw seems to be fine.
    Crap, I'm thinking, what now? I was NOT taking it back to that dealer, and I knew very little about the other Yamaha dealer in the area (though I have bought parts from them). I needed that broken bolt removed by someone I trusted. Someone whose talents were not in doubt.
    So I phoned a friend. He's not a motorcycle mechanic; in fact, I don't think he can ride a motorcycle at all. His day job involves repairing those majestic mechanisms of agricultural artistry, aka farm equipment. Balers and combines and so on, the more complicated and weird, the better. But I knew he was talented in the removal of broken bits, so I called him and asked, nay begged, that he help me out.
    He agreed. I dropped my poor stricken bike off at his place of work, where he said he would attend to it after hours. He pulled the other bolt, and pointed out to me where the threads were stretched... it would have given way just as easily.
    An aside... I am absolutely certain this is not my fault. I never use a tool having a lot of leverage on these bolts, and I've changed my own oil on this bike alone a half dozen times without any signs of trouble. On this particular occasion I was using a 1/4" drive socket attached to a short L-handle made of material even cheaper than the bolts themselves, and as I said, the bolts weren't feeling appropriately tight.
    Having left my true love in the capable hands of my friend, I set out to replace the broken upper-rear screw and its compromised upper-front sister. My friend had examined the lower screw and pronounced it unharmed, much as I suspected. I did some research, and learned a few things.
    Yamaha doesn't publish specifications for these screws, just part numbers, but some online research revealed that the rear is 6x25mm and the front is 6x75mm. I don't know a lot about thread pitch on metric screws, but my experiences had led me to believe they were standardized in some way so I wasn't too worried about that. In the course of my research, though, I learned (on this very forum) that earlier TW200's had JIS panhead screws in all three positions. With a JIS screwdriver in hand, overtorquing the screws would be a lot harder. I called that other dealer I mentioned above, and quoted the parts man the numbers for the older screws; he said they were still a current part (yay) but he had none of the front screws in stock (bah). He said they were on order, and would be in stock in a week or so.
    GAH. Who wants to wait?
    Curiously, though, more online research led me to a discussion about using screws from Fastenal as replacements for those older JIS screws. Naturally, American bikers who don't usually have JIS screwdrivers handy would find those screws frustrating, which may be why Yamaha changed them to hex heads. I DO have JIS screwdrivers, so I was cool with them; but really, any screw that did NOT have a hex head would suit me fine.
    I picked my bike up from my friend; he handed me the stub of the screw, and I put it in my pocket and took it to Fastenal just to verify the thread pitch was as standard as I thought. For $0.91 (yes, just NINETY ONE CENTS) I acquired replacements for both bolts.
    I installed them, rejoicing that they take the same 5mm Allen key that the lower screw requires, filled the bike up with oil and took a short ride to test everything out. They worked perfectly, no leaks or problems, and later I took a rather longer ride (about a hundred miles), checking the oil every time the engine was cool enough, and again, no problems.
    The only thing left to do is to figure out how to repay my friend, who said the whole job (including running a tap into the hole to make sure the threads were clean) took under ten minutes. Ten minutes or ten hours, doesn't matter to me, he saved my bike.
    Pleasanton, CA
    5,633
    Nice success story, glad that you are back in business!
    I'd say this job is worth a six pack of beer for your friend !
    Gerry and TWilight like this.
    Mar 2015
    Ynys Môn
    4,472
    Nice tale - and thanks for sharing - we might be the next ones in that predicament .....................
    TWilight likes this.
    - Hidden Content
    Aug 2010
    25
    My best advice? If the screws don't feel like they are getting tight, STOP.
    I guarantee I'll remember that.
    TWilight and amanduh like this.
    Aug 2010
    25
    I don't think he's a beer drinker... that would be easy, otherwise.
    I'll have to ask his wife for suggestions.
    Senior Member Dell's Avatar
    Aug 2012
    139
    If you are getting his wife involved, a gift certificate to a restaurant for two. This way she gets to appreciate his abilities more.
    Hidebound, TWilight and Byron like this.
    Aug 2010
    25
    Good point! Thanks!
    Hailey, ID
    3,265
    You certainly aren't the first one to do this!! I did it after 50 years of wrenching and using a correctly set 1/4 inch torque wrench! The current bolts just are not up to the old torque specs, if they ever were. I now use 2/3's of the published value.
    Your fix should last 5,000 oil changes.
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
    Senior Member Tuber's Avatar
    Sep 2012
    VT
    732
    Sounds like a deal. We have a Fastenal shop in town...think I might change mine just for the heck of it. I did that on my BMW too, so I could use an extended ball head Allen socket.
    2005 Tdub
    Junior Member mghonker's Avatar
    Sep 2014
    Vancouver Washington
    6
    Well boys....I just did the same thing. I had my torque wrench set and kept thinking...man this is too tight. I removed the top two bolts, double checked the wrench, and went at it again. Still seemed like a lot of torque. I again checked the wrench and this time made sure that it "Clicked" when I gave it a tug in the vice (seemed like a reasonable amount of force). So, back to the cover bolts. SNAP...... The long bolt broke right where the threads start. Man I feel like such a moron.
    So... after a quick eyeball, I think if I remove the right crank case cover I will have about 3/8 of an inch of the bolt sticking out of the crank case and I should be able to get at it.
    Are there any gotchas pulling the crank case cover? It seems like a straightforward removal, but given my apparent lack of finesse I am a bit anxious.
    BTW..... does anyone want a slightly used....made in China (and sold by Sears) Torque Wrench????
    Thanks!!!
  1. Oil filter cover gasket?
    By Joemama in forum Technical Help
    Last Post: 04-14-2014, 01:36 AM
  2. Oil Filter Cover O-Rings
    Last Post: 09-19-2012, 05:38 AM
  3. Oil filter cover leaking
    By junk munk in forum General Discussion
    Last Post: 10-25-2011, 12:15 AM
  4. oil filter cover leak
    Last Post: 10-16-2011, 06:55 PM
  5. 2001 Air Filter Cover
    By 1madhonda in forum TW200 Classifieds
    Last Post: 08-18-2011, 05:02 AM
