Starter Clutch Components - Mystery Part Discovered
Results 1 to 10 of 12
Like Tree15Likes
Thread: Starter Clutch Components - Mystery Part Discovered
    Senior Member arrowsmith's Avatar
    Missouri
    673
    I am changing the base gasket and this was in the pan under the motor. Where does it go?
    Senior Member jb882's Avatar
    Aug 2013
    1,377
    Did you take the flywheel off? It looks like one of the rollers that go in the back of the flywheel. I found a picture on google and circled the part. There should be 3 of them.
    Missouri
    673
    Yes fly wheel was off. I will go look.
    Thank you jb. That was it and it is back where it belongs.
    admiral likes this.
    Senior Member Borneo's Avatar
    Feb 2014
    6,368
    If that isn't it, you can always hope B-dub will stop by. https://tw200forum.com/forum/technica...placement.html
    admiral likes this.
    my blog Hidden Content
    Aug 2013
    1,377
    Quote Originally Posted by arrowsmith View Post
    Any time. The top one is almost guaranteed to fall out if you pop the flywheel with the motor on the bike.
    admiral likes this.
    Frosty Hollow
    13,100
    jb882 nailed it. Since you have it back together I'm showing this photo for the others. This shows the starter clutch on the backside of the flywheel. Make sure it has the Compression Spring, Spring Cap, and the Dowel Pin (aka puck).
    You may want ask the moderators to rename the title of this thread to something like: Starter Clutch Components - Mystery Part Discovered. That way folks searching for these components in the future could find it faster. Folks will not know what the "Mystery Part" is without opening the thread, which unless accidental is less likely in the future.
    Thanks for all those that helped.
    P.S. Because you were working on the base gasket, without you verifying you took the flywheel off, I thought it was possible the mystery part could have been the Hollow Dowel pins which help line up the cylinder and head. Like jb882, I was pretty sure this was a starter clutch dowel pin as it was solid, but unsure as normally a base gasket replacement wouldn't call for the flywheel be removed. Thanks for providing the picture and verifying it for us all.
    littletommy and Fred like this.
    Missouri
    673
    If I let the cam chain fall off the lower sprocket it is easier for me to put it back with the fly wheel off.
    admiral likes this.
    Senior Member RobG's Avatar
    Jan 2015
    Fulltime in an RV (currently PNW)
    1,076
    I'm glad Admiral posted what he just did because i was about to do the same. I had mine apart back in March and replaced a missing puck, spring and dowel pin on mine. Without it, your starter clutch won't work and you'll be kickstart-only (if you have one).
    '12 Suzuki V-Strom DL650
    '96 Suzuki DR650
    '92 Yamaha TW200
    Hidden Content - Organize your rides online!
    rbm
    rbm is offline
    Senior Member rbm's Avatar
    Jan 2011
    4,305
    Good info here! Title changed and thread stuck.
    admiral and wolfy like this.
    Member LittleTen's Avatar
    Dec 2015
    33 hrs southeast of LittleTommy
    93
    Just goes to show how good two ums + two ums work to help all make good workie-workie..... longtime!
  1. clutch basket tool.....part number.
    Last Post: 12-02-2014, 06:19 PM
  2. Replies: 2
    Last Post: 09-04-2014, 08:12 PM
  3. Flywheel starter clutch question
    By ldw72120 in forum Technical Help
    Last Post: 09-18-2013, 09:30 PM
  4. TW Lowering Components - XVS 100 Shock
    By mpilla in forum TW200 Classifieds
    Last Post: 11-11-2012, 09:33 AM
  5. TW Lowering Components XVS1100 Shock
    By mpilla in forum Performance and Customization
    Last Post: 11-06-2012, 12:05 AM
