Joemama swingarm extention
Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Like Tree3Likes
Thread: Joemama swingarm extention
    Senior Member Joemama's Avatar
    Apr 2012
    Lake County, Ca.
    1,238
    I recently completed a couple of extended swingarm projects for my riding partners. I am sure there are other ways of doing this, but here is how I did these. First I marked the two donor arms to gain a 2' extiention.
    I used a piece of allthread in the axle location to maintain the proper width and made the cuts with a sawsall.
    I made inserts from 1x1.5 box tubing and 1/4x1 flat strap for a total of 1" x 1 3/4"
    Apr 2012
    Lake County, Ca.
    1,238
    I drilled 72 1/4" holes for plug welds, put the inserts in and slid it all together. It was a very snug fit, thus the Idaho persuaders.
    All true and ready to be welded.
    All welds completed and ready for clean up.
    I used a flap wheel grinder to clean the welds up.
    Apr 2012
    Lake County, Ca.
    1,238
    The front chain guard tabs were moved back 2".
    A really good clean up in the bead blaster and it is ready for paint. Silver or black?
    I hope it all works out for you Joeband. LETS RIDE!
    joeband likes this.
    6,931
    Talk about talent, nicely done!
    Frosty Hollow
    12,903
    Nice job on the extension.
    Idaho persuaders, love the tool set!
    18,402
    Impressive work there Joe. So that's how it is done!
    How long of an insert can you persuade into the respective donor arms?
    Nov 2011
    norcal nutjob
    3,287
    hey! i know that picture was a long time ago... i had brown hair! that was the first ride with my infamous creek crossing; wet socks for lunch!
    thanks joemama, i don't know that i am worthy of such a work of art, but i am very appreciative!
    thank you sir!
    ps: like the rolling stones said: paint it black
    Apr 2012
    Lake County, Ca.
    1,238
    The true straight section is only 5" long on a stock arm. The insert is 7" long. Snug on both ends as well as the entire length. There was no motion at all when it was ready to be welded.
    Pleasanton, CA
    5,629
    Dang, Joemama! 72 holes and plug welds! I'll bet you were glad I didn't come back and ask you to add another 1/2" to mine , that sucker is never coming apart!
    Seeing the fabrication process steps makes me appreciate your efforts even more - thanks again Joe!
    Outstanding work!
    Apr 2012
    Out West
    2,998
    wow that's bullet proof for sure and much stronger than the stock "thin wall" arm !!!!!
    "It's Like Warm Apple Pie"
  1. The NorCal Nutjobs' After-Thanksgiving Ride at Joemama's - Saturday, November 28
    By TW-Brian in forum Trails, Off-road, and Adventure Riding
    Last Post: 12-01-2015, 11:21 PM
  2. Joemama and the Rock WildFire
    By Fred in forum Off-Topic
    Last Post: 08-09-2015, 09:25 AM
  3. Say it ain't so, Joemama!
    By TW-Brian in forum General Discussion
    Last Post: 07-31-2015, 10:53 AM
  4. Extended Swingarm - Courtesy of Joemama Industries
    By TW-Brian in forum Performance and Customization
    Last Post: 01-19-2015, 10:51 AM
joemama induestries
joemama swingarms
