CDI repair - Page 3
Page 3 of 11 FirstFirst 12345 ... LastLast
Results 21 to 30 of 103
Like Tree249Likes
Thread: CDI repair
  1. #21
    Senior Member WECSOG's Avatar
    Jun 2015
    2,417 miles from LT! ;-]
    729
    Quote Originally Posted by tombauer View Post
    TW and BW CDI's do not use a microprocessor. They use a crude time delay with a quad op-amp at its heart. Honda mower CDI's use a dedicated time delay IC but much the same result. I have true microprocessor controlled CDI's for 1985 to 2000 BW and TW bikes. Need some people to test them on actual bikes and report the timing just for fine tuning of the curve.
    Thanks for the reply. Are your CDIs user-tunable? That would be a nice feature.
    '87 TW200
    '94 Sportster 1200
    '74 XL70 Frankenbike
    '76 CT90
    '72 CT70
    '72 XL250
  2. #22
    Senior Member tombauer's Avatar
    Jun 2017
    Sadly, Maryland
    147
    For such a slow and low power bike, I don't see any reason to make them that way, it would add to the cost. I am considering having a tach output wire. If someone wanted a custom curve it certainly could be done. There is one being designed now that is tunable from a smart phone with wi-fi.
  3. #23
    Pleasanton, CA
    5,643
    I like the idea of having a tach output!
  5. #24
    Jun 2017
    Sadly, Maryland
    147
    10 CDI's made today, 4 with wiring harness, 1 for 1987 and 3 for 1988 to 2000. Programmed with this advance curve.
    Rev limiter set at 9500, unique power supply allows for use of any of the Yamaha high voltage supply to power the microprocessor.
    These CDI's do not support the interlock for stand and clutch but it is just bypassed and will work only without killing engine.
    Next version will have tach output, support stand and clutch. DC powered CDI's also available and have a very much hotter spark.
    littletommy, elime, Ken and 7 others like this.
  6. #25
    Pleasanton, CA
    5,643
    10 CDI's made today, 4 with wiring harness, 1 for 1987 and 3 for 1988 to 2000. Programmed with this advance curve.curve.jpg
    My suggestion would be to send the prototype 1987 unit to Elime (Tony) who is the resident guru for getting every last bit of performance out of his two 1987 TW's. He recently acquired a new CDI from Yamaha so he would be able to compare the performance of your unit versus a known good stock one.
  7. #26
    Junior Member Ian43ktm's Avatar
    Aug 2017
    Brisbane Australia
    11
    Hi Tombauer. Are you selling these CDI's? I have an 88 mod bought recently. I suspect that the CDI in it is a Chinese copy. It looks nothing like pics I see for a genuine one . How much and do you mail to Australia?.....................Ian
    littletommy and jtomelliott49 like this.
  8. #27
    Sep 2012
    Wichita, KS
    1,857
    Tombauer you may have found another product to add to your "niche" business, while helping a lot of folks who don't want to give up on their TW's with the bad cdi's. Best of luck to you in this pursuit.
    littletommy likes this.
    Tom in Wichita
    78 Moto Guzzi SP1000
    87 Yamaha TW200
    99 Yamaha TW200
  9. #28
    Jun 2017
    Sadly, Maryland
    147
    Quote Originally Posted by Ian43ktm View Post
    USPS to Australia is $35. I hope to have some tested in real life in a few days.
  10. #29
    Frosty Hollow
    12,912
    Back Story.
    I recently obtained a 1983 XT200. It was reported to have had CDI's replaced as part of its history. The XT200 is an unusual setup with a 6V system instead of 12V. It was mentioned there was a possibility the CDI's would go bad if run without the battery.
    Current story.
    So when it warms up it will spit and sputter then giving it some throttle. I'm cleaning/repairing the carb but the symptoms are similar to what I've seen written about for the 1987 TW's. I have ordered a new cdi in case this is the problem and not the carb. Can't really go wrong with having a spare cdi for a 1983 motorcycle should the cause be the carb just the same.
    Future story.
    Should I find the cdi to be the issue with this "almost TW", I might have an XT200 cdi for you to work on if this would be of any interest to you. If repairing/rebuilding an XT200 cdi is something you'd be interested in let me know.
    Thanks
  11. #30
    Jun 2017
    Sadly, Maryland
    147
    i would like to see the wiring diagram. if you have one scan it as a jpg with high resolution, so it will be a much cleaned scan.
    if it is like the BW and TW 200's here be very careful using any other than the proper CDI. the timing could be so far advanced it will damage the engine or so far retarded it will run hot.
  1. '87 CDI Repair
    By radbuggy in forum Technical Help
    Last Post: 01-12-2016, 12:07 PM
  2. Helmet repair
    By SickPuppy76 in forum Technical Help
    Last Post: 09-07-2015, 08:31 PM
  3. Source Coil Wiring to CDI - GY6 CDI Troubles
    By Oleschool in forum Technical Help
    Last Post: 08-17-2015, 08:14 AM
  4. Exhaust repair (Help)
    By tcepilot in forum Technical Help
    Last Post: 11-10-2014, 09:58 PM
  5. Petcock repair
    By Tirebiter in forum Technical Help
    Last Post: 04-15-2013, 07:23 PM
news
