changing/servicing brakes for 1998
Results 1 to 10 of 11
    Junior Member cat 4 life's Avatar
    Jun 2013
    11
    Are there any good posts/topics with write-ups on servicing and changing front and rear brakes with pictures for a 1998?
    If so could you link them here, I can't seem to find any in my searches.
    Thanks
    Ephrata, WA
    1,125
    You're right, I don't think there is much info on the front and rear drum brake setup.
    Very easy to do. Hardest part is getting the brake cable set correctly.
    What do you need to know? I'd be happy to take pictures for you or even a video.
    Looks like a lot of stuff in there, but its really simple. Two pads, two springs, a pivot point and thats about it. The fronts have a few other parts but you don't need to mess with them.
    First time I did it I knew nothing and it was pretty simple. Let us know if you need some help.
    1990 TW200
    Jun 2013
    11
    How easily does the speedo cable come out? I removed the little clip before pulling it out but it just won't come out?
    Ephrata, WA
    1,125
    [media]http://www.youtube.com/watch?v=YMpfJrRL-Tw[/media]
    Here you go. Took a little longer to upload than I thought. My brother actually posted it for me.
    Disclaimer-This is my first "how to video" so please be kind. I know there is more than one way to do brakes so if you have a different way let us know.
    Total raw video was 38 minutes. That included a couple "re-takes", dropped tools, etc.
    1990 TW200
    Ephrata, WA
    1,125
    Quote Originally Posted by cat 4 life View Post
    Speedo is easy. Pull out the tab with some needle nose pliers by squeezing the ends together, and then just pull on the cable straight out.
    1990 TW200
    Senior Member turborob's Avatar
    Australia.
    553
    Rainman, did you carve those grooves into the 'pads'?
    I'm sure my '93's aren't like that.....
    Ephrata, WA
    1,125
    Quote Originally Posted by turborob View Post
    No I didn't. Those were the pads off of a parts bike I had.
    1990 TW200
    Jun 2013
    11
    Thanks for the video. I had to replace the front brakes and totally remove the cable off of the bottom drum because my brakes were way out of wack. So now, how far do I screw the bottom two nuts up the bolt on the drum for a starting point. I know that you can also adjust the brakes using the bolt/jam nut on the perch but where/how should a guy start?
    Thanks
    Ephrata, WA
    1,125
    Mine are all the way to the bottom.
    1990 TW200
    Senior Member B-dub's Avatar
    Jul 2011
    Southwest Utah
    2,132
    Excellent video, Rainman. It was thorough and well presented. Since it's helpful for a lot of people to see it done, you really should create another thread and plug that video into it so it can be stickied. This thread would work but it specifies for a 1998. I would also like to see your directions for removing the swingarm and changing out the chain slider put where it can easily be found. That was also very well done. Thanks for sharing your expertise. You're a great wrench and videographer as well as TW racer!
  1. 1998 tw200 metal tank
    By kennethshaw in forum TW200 Classifieds
    Last Post: 07-17-2012, 05:27 PM
  2. POND servicing
    By TWBARR in forum Off-Topic
    Last Post: 05-29-2012, 08:31 AM
  3. 1998 carb for sale
    Last Post: 04-25-2012, 11:00 PM
  4. Looking for 1998 exhaust header and muffler
    By JTH90 in forum TW200 Classifieds
    Last Post: 04-06-2012, 01:16 AM
  5. Dallas Area on CL - 1998 TW $900
    By eaglescall in forum TW200 Classifieds
    Last Post: 09-17-2010, 10:47 PM
1998 tw200 breaks
removing speedometer cable tw200 drum brake
tw200 break cable1990
tw200 break pad replacement
tw200 front drum brake
tw200 remove front drum brake
