Removing the Carburetor Float
Results 1 to 9 of 9
Like Tree3Likes
  • 2 Post By jbfla
  • 1 Post By qwerty
Thread: Removing the Carburetor Float
    Senior Member jbfla's Avatar
    FL. GA, NC
    2,399
    Removing the Carburetor Float (updated 8-4-2017)
    This is for informational purposes only. Proceed at your own risk.
    Here's one of the things that the manual tells you to do, but does not tell you how to do it.
    There is a potential for serious damage to your carb body if you are not careful.
    These are the parts you are trying to get to by removing the float.
    When you remove the carburetor float, float needle valve, and seat you can:
    Examine the parts for wear (tip of needle valve and o-ring).
    Clean residual gum or varnish left behind by evaporated gasoline.
    A friend of mine repairs small engines. I have seen him take a small hammer and punch, and tap a float pin out in the blink of an eye.
    If you are tempted to do this, please be careful, and put a support under the post you are tapping on (and don't blink!).
    The aluminum posts are fragile. A heavy blow will break them off.
    If you are still determined to remove the float, I would like to offer an alternative method of removing the float pin.
    Using a pair of adjustable pliers (channel locks), gradually increase the pressure on the pin, and push the float pin flush to the post.
    Then use a small brad or finishing nail to complete pushing the float pin through the post.
    I feel that by using the pliers, I have more control over how much force, or pressure, is placed against the pin and post.
    There is still a possibility of damage by heavy handed use of the pliers.
    Here's the carb with the float removed.
    Remove the retaining screw and seat, and clean the parts.
    (If the seat is stuck in place, you may need pliers to remove it. The brass seat is easily damaged by steel tools. You may need to replace the seat with a new one if you damage it.)
    Examine the o-ring. Replace it if it is dry and flattened. An old o-ring is one of the causes for the carburetor to leak gas.
    After cleaning the needle valve and seat assembly, put everything back in the carb body, and press the float pin back in place.
    Before you put the carb bowl in place, check to see that the float is working properly.
    Gently press down on the float, and release it.
    It should move smoothly and spring back into place.
    If you keep your TW for a long time, you may be performing this procedure more than once.
    To make it easier, you can drill the hole in the float post slightly larger, so the pin easily slides in and out.
    It won't fall out. The shape of the float bowl will keep it in place.
    jb
    fujimo and Rickhem like this.
    Might I suggest that when you are pressing the float pin back into place that you open the channel locks and put the top jaw on the post with the arrow? Reasoning is the post with the arrow is the one against which the pin pushes. As shown in the picture, the posts are being squeezed together.
    FL. GA, NC
    2,399
    Qwerty,
    Thanks for your observation.
    Photo has been corrected.
    jb
    Quote Originally Posted by jbfla View Post
    Qwerty,
    That's a good suggestion, but aren't the posts being pushed apart, not together?
    As shown above, the jaw on the right post is pushing to the right, and the jaw on the end of the float pin is pushing the pin against the post on the left.
    Here's a corrected picture where the post that is being pushed against by the pin is supported.
    jb
    You are correct about which way the posts are being pushed. It was a long day. Doesn't matter. Your new photo eliminates all stress on the carb body and is the best way to do it. Maybe you should go back and edit the opriginal post?
    By the way, I'm glad you started this thread. I've seen many broken carb bodies from incompetent float removers over the years. Those pot metal carb bodies are quite fragile.
    JerseyJeeper likes this.
    Senior Member 805gregg's Avatar
    Oct 2010
    572
    Great job thanks, I will be going into my carb, soon I've got a 132.5 main jet and a 130. I think I will go big. And those nails are not finishing nails, I don't care what the clowns on the TV say, it's a finish nail (says so right on the box), small head to recess, and fill.
    Senior Member Gerry's Avatar
    Paradise, Calif.
    3,514
    Very nice.. And appreciate the update. Thanks, Gerry
    Take care my Friend.........
    Senior Member Stromper's Avatar
    Oct 2011
    Eastern Connecticut
    443
    Note Carb float metal bracket very flimsy take great care not to tweak them
    Jun 2011
    Dothan, AL
    1,715
    Thanks for this post!
    I was having a really tough time with the float pin until I found this thread.
    My 2005 has 5000 miles and the o-ring on the needle valve seat was completely shot. Almost nothing left to it. Ordered the need assembly and it was a snap to change using this method.
    These pictures need to be added to the other carb pictures and this jet tutorial These need to be pinned or combined to make a comprehensive carb work tutorial.
    2005 TW200 (SOLD)
    2013 DR650
    Senior Member dubstep's Avatar
    Oct 2010
    Hong kong
    453
    great post - appreciate the clean concise effort!
    2001 TW200 - supertrapp stubby exhaust
    1996 CRM 250 - 2 smoker - FMF exhaust
    1998 Honda CB600 Hornet - ( a.k.a Honda 599 ) - micron , ohlins rear - CB600F3 front forks..
  1. Carburetor jet kit
    Last Post: 04-16-2013, 09:00 AM
  2. Problem removing float hinge pin ( older style carb )
    By Bucknutz in forum Technical Help
    Last Post: 04-15-2013, 05:25 PM
  3. (SOLD) New never used Carburetor from MR. Motorcycle
    By nfish in forum TW200 Classifieds
    Last Post: 07-18-2012, 12:39 PM
  4. Carburetor Style of 1994 TW
    By dakman74 in forum Performance and Customization
    Last Post: 08-17-2011, 07:41 AM
  5. Carburetor help or different carburetor options
    By dz1 in forum Technical Help
    Last Post: 05-21-2011, 08:24 PM
carburetor needle seat
float pin
float pin in yamaha
how to clean carborator 1987yamaha tw200
how to remove the float in a carburetor
how to remove yamaha xt225 carb
how to take the float out of a mikuni carb
remove carb tw 200
remove tw200 carburetor
removing the float from carb 92 tw200
tw200 carb removal
yamaha at3 float valve removal
