carburator upgrade
Results 1 to 4 of 4
    Junior Member neverseemefall's Avatar
    Sep 2010
    So Cal desert
    14
    I see that the xt225 is suitable for a Mikuni TM33-8012 Pumper Carb upgrade. What about the tw200? If not the Mikuni TM33-8012 Pumper Carb, then what other carb would be suitable?
    Desert, SoCal
    7,369
    The carb ain't really the problem.
    Sep 2010
    So Cal desert
    14
    Is "The Problem" is that it is just a TW200, a bike outfitted with a motor that just isn't very suitable for extensive mods, and that I should be happy with rejetting, opening up intake and exhaust flow a bit, and perhaps just a little bit of cam work? Cuz if that is what it is, then I will humbly bow to my elders in this forum, and resist my habitual compulsion to over-modify...but maybe just a little bit would be ok.
    Desert, SoCal
    7,369
    LOL. You pretty much nailed it. Still, no reason not to experiment.
    The TW hits a bottleneck once the fuel charge leaves the carb, and for that reason I think the stock carb would flow enough for even the most highly modified TW.
    I do think a flatslide could have some value, but for the expense involved with that particular conversion I think it's overkill. I'd try to work with one of the dime-a-dozen 28mm Mikunis.
  1. Carburator drain screw stripped
    By Matojo in forum Technical Help
    Last Post: 10-20-2015, 02:51 PM
  2. carburator throttle linkage
    By HercJerk in forum Technical Help
    Last Post: 03-30-2013, 08:49 PM
  3. Carburator float towers
    By Cagiva in forum Technical Help
    Last Post: 11-03-2012, 11:17 AM
  4. Power and Top End Upgrade
    By JD_ in forum General Discussion
    Last Post: 09-03-2012, 07:24 AM
  5. Cam upgrade
    By Skyking in forum Performance and Customization
    Last Post: 01-07-2012, 01:39 PM
