New battery
Results 1 to 7 of 7
Thread: New battery
    Junior Member trbixler's Avatar
    Mar 2012
    9
    It is time to put a new battery in my 2005 tw200 other than an OEM battery does anybody have any suggestions
    Senior Member FortPayne's Avatar
    Nov 2011
    Alabama
    326
    I went with a much smaller battery. Advanced auto was by far the best priced, I checked around. It will run the starter fine but I usually kick start it so just needed a small battery to stabilize the lights and electrical. Have had it since christmas and havent charged it once since initial charging.
    Tenaciously Deviant Unwittingly Brilliant
    Mar 2012
    Boonville, No.-Calif.
    1,357
    Can you drop $103.00? Then do yourself a favor and get a Shorai Lithium-Ion battery! It does not go low from sitting for a few weeks, & there is no acid to spill! Read up on it. Lives up to its reviews.
    Part # LFX09L2-BS12. m.
    Sep 2011
    Southcoast MAsshole
    2,661
    i posted a few links in this thread you can check out...
    https://tw200forum.com/index.php?/top...__1#entry39560
    Senior Member mrlmd's Avatar
    1,153
    If you wind up getting a new AGM battery, remember to fully charge it up first before first use or the battery will be damaged and never hold a full charge and you will be back at the store getting a replacement. They do not come charged when you buy them, regardless of what the salesman says, you have to make sure it's done, or if you have to fill it yourself it must be charged before you can use it.
    Member vn_grnt's Avatar
    Jul 2011
    Bandon, Oregon
    77
    Hi,
    I put a Ballistic EVO2 8 cell in my 93 because even a new Yuasa turned it only so so, the Ballistic REALLY cranks it solidly. It's been 30+ degrees where I am and it spins it with NO problem.
    The price is a lot; about $140.00 from the shop. I could have ordered it alot cheaper online, but I'm the "Too impatient" type.
    I went to the shop looking for the Shorai battery but they didn't have any (the dealer locator says they're a dealer, but they were out). I'm happy though.
    E
    Mar 2012
    9
    Thanks to all for your input I think I will look into the up grade as my tw does not have the kick start and the last thing I want is to be in the middle of no were with a bike that will not start I sure wish they would have not taken the kick start off the newer years .
  1. Battery
    By mga60tw in forum Technical Help
    Last Post: 07-24-2016, 03:57 PM
  2. New Battery Help
    By cptrout in forum General Discussion
    Last Post: 12-05-2012, 08:12 AM
  3. Best battery?
    By Matthew Rowland in forum Performance and Customization
    Last Post: 02-06-2012, 10:02 AM
  4. How do I get to the battery
    By mike m in forum Technical Help
    Last Post: 02-14-2011, 09:27 PM
  5. Run w/o battery OK?
    By Rohnsman in forum Technical Help
    Last Post: 01-30-2011, 01:32 PM
oem battery tw200
tw200 oem battery
