Oil cooler adapter filter covers available - Page 7
Page 7 of 7 FirstFirst ... 567
Results 61 to 70 of 70
Like Tree95Likes
Thread: Oil cooler adapter filter covers available
  1. #61
    18,807
    The banjos are a nice feature.
    Road going types can mount the radiator lower and use skid plate as an additional heat sump, I saw this once.
    Longer oil lines can relocate cooler in a variety of places but at the expense of some oil circulation efficiency.
    Teddy Bear, will post photo of the CPU fan and ducting plus coper coil heat exchanger from Gerry's Mr.Gizmo bike, a little crude and muddy from the field but has worked well for last decade or so:
    Donzo, Teddy_Bear and Ken like this.
  2. #62
    Member Tom Bentzen's Avatar
    Aug 2010
    Cle Elum, Washington
    53
    Does the piece that replaces the stock engine cover NEED a gasket???
  3. #63
    18,807
    Tom, if you are referring to to LZRDBRETH cooler set-up that replaced the oil filter housing cover then"YES" , the new filter cover that features the needed oil pick-up and return lines needs, and re-uses, the stock OEM Yamaha cover gasket.
    jbfla likes this.
  5. #64
    Aug 2010
    53
    Thank you.
  6. #65
    Aug 2010
    53
    I just got my bike. When I crack that cover is oil going to come spilling out?
    littletommy likes this.
  7. #66
    Apr 2012
    Out West
    3,057
    Quote Originally Posted by Tom Bentzen View Post
    just a tablespoon in the oil filter nothing to worry about the entire bike only holds a quart
    jbfla and littletommy like this.
    "It's Like Warm Apple Pie"
  8. #67
    Aug 2010
    53
    Any idea how much extra oil Im going to have to add when the cooler is in place?
  9. #68
    Pleasanton, CA
    5,740
    Not much, less than a shot glass.
    Just keep your oil level near the top line on the sight glass and you will be fine.
  10. #69
    Aug 2010
    53
    Well, the only time there would be oil in the cooler is under power. So, If I keep the level at the top of the line there will still be enough in the crank case to Lub the engine???
  11. #70
    Pleasanton, CA
    5,740
    Yes,.
  1. oil cooler crushing filter
    By joeband in forum Technical Help
    Last Post: 04-19-2016, 09:35 AM
  2. WTB - Oil Cooler looking for an Oil Cooler Kit
    By Skin Walker in forum TW200 Classifieds
    Last Post: 01-01-2016, 05:15 PM
  3. For Sale (2) TW 200 Oil Cooler Adapter(s) Lizard & Jap Version
    By PlacerLode in forum TW200 Classifieds
    Last Post: 01-12-2015, 05:25 PM
  4. sprocket change and lizrd oil cooler adapter
    By GOBB in forum Performance and Customization
    Last Post: 01-19-2014, 07:15 AM
  5. Oil Cooler Adapter
    By GapRunr in forum Technical Help
    Last Post: 03-09-2012, 09:46 PM
news
tw200 oil cooler
tw200 oil cooler for sale
tw200 oil coolers
yamaha tw 200 oil cooler housing cover for sale
yamaha tw200 oil cooler filter sandwich adaptor kit
