Kick starter kit, Carb, D.I.D. chain and more misc parts.....
Results 1 to 10 of 12
Like Tree11Likes
Thread: Kick starter kit, Carb, D.I.D. chain and more misc parts.....
    Senior Member randucci's Avatar
    Mar 2012
    Seattle, Wa.
    134
    All SOLD, thanks!
    New in box Yamaha XT225 Kick starter Kit, PN: 3RW-W0795-00, $250.
    Note: a TW200 kick lever "boss" will need to be purchased and switched out with the XT225 "boss" to work on the TW200.
    Basically new Yamaha carb, PN: 5FY-14301-10., it has a 128 main jet. I mounted the carb and ran the bike a couple minutes, then took it off, I ended up modifying the original carb and never used this one again. $250 and it also comes with the following new Yamaha parts:
    (2) needle and seats
    (1) 128 main jet
    (1) 130 main jet
    (1) float bowl gasket
    Also (1) used carb to cylinder head manifold and some various thickness needle shims.
    D.I.D. 428V O-Ring chain, PN: 132FB, $70.
    Stock shock and spring, plus a Daytona spring, $70.It will lower the bike about 1.25"
    Misc. Yamaha parts, All new, $20 for all:
    (1) gas tank valve, PN: 23F-24500-1
    Head pipe washers, insulator washers, screws and headpiece gasket
    (2) valve lash adjuster screws
    (1) air box seal, PN: 1VJ-14462-00
    (2) valve cover o-rings
    If you take it all, I'll make a package deal of $480. I accept PayPal and USPS Money Orders and ship via USPS Priority Mail, International orders will have a shipping charge.
    Purple likes this.
    Senior Member putt-putt's Avatar
    Oct 2017
    Vancouver Island
    221
    Pardon my ignorance but will this kickstart fit a TW200 or is there more to the install?
    TIA
    putt-putt
    Mar 2012
    Seattle, Wa.
    134
    Quote Originally Posted by putt-putt View Post
    TIA
    It will fit.
    Mar 2015
    Ynys Môn
    4,546
    Quote Originally Posted by randucci View Post
    It will fit.
    Does it cover the "boss" issue ?
    - Hidden Content
    Mar 2012
    Seattle, Wa.
    134
    I am not familiar with the "boss" issue, so I don't know, sorry. The kit contains what a 3RW-W0795-00 is to have in it, maybe someone else can comment on it.
    Mar 2015
    Ynys Môn
    4,546
    It would appear that you need a “TW specific” boss – the bit that goes on the spline/threaded bit that sticks out of the crankcase bit
    https://tw200forum.com/forum/tw200-cl...evers-etc.html
    https://tw200forum.com/forum/performa...k-start-2.html (post #11)
    Although the 225 parts are all quire correct for the TW200, the one exception is the TW200 “boss” – the splines are slightly different. It’s only a small easily correctable single (additional) part issue, but I thought I’d mention it before someone (like me) tried a clump hammer fix ……
    JerseyJeeper and putt-putt like this.
    - Hidden Content
    Mar 2012
    Seattle, Wa.
    134
    OK, I opened up the XT225 crank kit and it did have the smaller XT "boss" kick lever, so a TW "boss" would need to be switched out.
    Purple likes this.
    Mar 2011
    NJ Shore / Pine Barrens
    3,880
    PM sent for package deal.
    Purple and TopPredator like this.
    Husqvarna TE300i Fuel Injected 2-Stroke 2019
    Yamaha XT225 - 1999 Serow
    Yamaha TW200Z - 2010
    Yamaha BW200 Electric Start! - 1986
    Yamaha TTR225R - 2003
    Husqvarna 701 Enduro - 2017
    Kawasaki Prairie 650 - 2002
    Mar 2011
    3,880
    PayPal Sent..
    Purple likes this.
    Jun 2014
    Bel Air Maryland
    4,169
    Quote Originally Posted by JerseyJeeper View Post
    That shock would look good painted red on the Black Widow
    If I’m ever on LIFE SUPPORT, UNPLUG ME. Then plug me back in... See if that works. Hidden Content
    TW 2006 Ruth
    TW 1988 Black Widow.
    1994 Harley FXR
    Rick
  1. Replies: 2
    Last Post: 03-13-2016, 07:48 AM
  2. kick starter kit
    By supachip1 in forum Technical Help
    Last Post: 03-05-2016, 06:53 AM
  3. Wtb: Kick starter kit
    By wbpolk in forum TW200 Classifieds
    Last Post: 04-15-2015, 10:23 AM
  4. Kick Starter Kit on the Way!
    By scotti158 in forum Technical Help
    Last Post: 09-27-2014, 08:51 PM
  5. kick starter kit
    By grounder in forum Technical Help
    Last Post: 02-28-2012, 05:25 PM
