Mikuni carb test
Results 1 to 10 of 15
Like Tree9Likes
Thread: Mikuni carb test
    Member tumbleweed's Avatar
    Apr 2012
    Indianapolis, IN
    61
    Mikuni carb test
    Mikuni TMR28. Movie is one minute, I thought maybe someone can enjoy this sounds. Have a nice day.
    Senior Member Heli-Mech's Avatar
    Jan 2014
    Dartmouth, Nova Scotia
    379
    Having installed a FCR pumper carb on my xr650l before .... I know the benefits and power delivery feel that a pumper carb can provide. It was a "night & day" conversion on the xr650l.
    So a few quick questions?
    - where did you source the carb?
    - what size jetting are you using?
    - are u using the stock intake boot?
    - what about the air filter/box side?
    Great work and it should be a amazing upgrade.
    Cheers,
    Ian
    Senior Member 1911garand's Avatar
    Nov 2015
    Great White North
    714
    Excellent! Specific details please!
    Yamaha - 1992 TW200
    BMW - 1995 R1100GS
    Mar 2011
    NJ Shore / Pine Barrens
    3,880
    Quote Originally Posted by tumbleweed View Post
    So many questions
    I've been trying to find one of those for a reasonable price. Were you able to get a boot hooked back to the factory air box. I believe that carb may have been designed for a funnel on the intake side. What does the intake flange measure in mm?
    Were you able to get the float bowl "level" enough when mounting to the factory intake to set the float correctly? Some pics would be great!
    Webike has the red anodized one but at over $600.00 plus shipping no thanks.
    Is it this exact one that you have:
    Apr 2012
    Indianapolis, IN
    61
    Thanks for interest more than sound. My answer for most of questions are "That's I'm going to try to figure out."
    Story: I bought this carburetor brand new almost 20 years ago for Honda XR250 flat track motor. I use little bit and switch to TMR34. TMR28 carb was slept for a while since then.
    Carburetor was come with me when I moved from Japan. Yes, it was very expensive piece but I was racing so, power is important more than anything.
    We can buy this adaptor instead funnel for using K&N or some after market airfilter. diameter is 50mm so, OEM rubber boot will not fit.
    For fitting, Intake manifold need 180 degree up side down as shown like picture.
    Then people use funnel because shock spring positioning right behind. There is no space for air filter or rubber boot. I guess float level is no problem because this is how they install and using.
    Also needs throttle cable holder replace(Parts #8). That piece you can buy from only Yoshimura Japan or you have to make your own.
    I use for dirt track ride, can't ride without air filter. It just so many work, I do not recommend this modification to anyone. better go Mikuni TM33-8012. That's easy, less cost, more power. I just doing what I have.
    This thread has info too. https://tw200forum.com/forum/tw200-pi...ile-track.html
    Thanks.
    Spokane, Washington
    17,257
    Thank you for sharing that.
    1st John 1:9
    John 3:16
    John 3:17
    Jan 2014
    379
    Thanks for the info/pics and reply.
    I love finding a use for a old off the shelf part. If I can find another FCR 250cc MX carb locally for cheap I will be trying to retrofit it to my TTR225/TW engine build. The problem is they are a BIG carb so a lot of custom work will be required to mount it up. If not the TM33 looks like the ticket.
    All the best with your build and make sure to keep us updated on your project.
    Cheers,
    Ian
    Mar 2011
    3,880
    Thank you Tumbleweed. I corresponded with some people in Japan just last week on this. You filled in some blanks. I'm also looking at the 33mm
    JJ
    Apr 2012
    Indianapolis, IN
    61
    Hello all,
    Here is my update but feels me like it should goes different thread so, I just upload to my blog.
    Please check that out if you have interest.
    LIFE IS SIDEWAYS: Mikuni TMR project
    Thanks
    tumbleweed
    PS: To Heli-Mech, MJ is #125 and SJ is #22.5 for now. Looks and feels like slightly rich on low revolution part by these jets and K&N filter combination. (198cc motor.)
    Heli-Mech likes this.
    6,955
    This place has TM28-1 and TM33-12 carbs for a lot less than $600.
    Carburettor MIKUNI TM28-1 | SIP-Scootershop.com
    Carburettor MIKUNI TM33-12 | SIP-Scootershop.com
  1. Mikuni BSR 42mm carb - trade?
    By 1911garand in forum TW200 Classifieds
    Last Post: 12-22-2015, 06:25 PM
  2. Replies: 8
    Last Post: 10-29-2014, 10:14 PM
  3. Where can I buy Mikuni carb for 89 TDub?
    By Holdnon72 in forum Technical Help
    Last Post: 06-05-2014, 01:39 PM
  4. Mikuni TM28 Carb kit & Oem tk *SOLD*
    By PalmStateCrawler in forum TW200 Classifieds
    Last Post: 04-25-2013, 09:49 PM
  5. Mikuni 30 MM ebay carb
    By Stromper in forum Performance and Customization
    Last Post: 11-08-2011, 01:16 PM
tmr28 mikuni on tw200
