21 - 34 of 34 Posts
Is it gas in the air filter, or could it have been oil?
If it's gas, the float of the carburetor may be stuck and flooding. If that's the case, I'd just buy a new one. As you can see, they're super cheap!
Popping/backfiring is an indication that unburned gas is getting past the engine and in to the exhaust, where it ignites and explodes. This can be due to a timing issue, or also a bad spark plug, or also weak spark due to a bad coil or CDI, and maybe even other things. Replace the spark plug, if you haven't already.
It's my advice that you not try to fix a bunch of prospective problems at once - This makes it difficult to pinpoint the problem. One thing at a time, in my opinion.
Discussion Starter · #22 ·
Sure Smelled like gas but could be oil. I can buy a plug and try that. Buying a carb is cheaper than a kit LOL
Was having starter issues and played around testing and bought a Starter relay but wasn't the issue. Starter worked out of case but not in. Having a battery delivered today and hoping thats the issue.
thanks for the help
The reason I'm asking, is that you typically lightly oil the air filter after cleaning. If it's saturated, you'll want to wring-out some of that oil. If it's gas, then it's a carb issue.
Where are you located?
The angle of your throttle assembly on the carb needs to be changed. Search this forum for clone carb installs.
Discussion Starter · #25 ·
Yes, totally and Im all for the questions :)
Im in Laguna Beach CA
Resolve that stuff and let us know. There are lots of really knowledgeable people here, and many of them have worked with the Chinese carbs. Keep asking questions and someone will answer.
You need to determine if it's a fuel problem, first. When that's eliminated as the culprit, then you can move on to more expensive items, such as the CDI.
If you're getting consistent backfiring, then it's likely it's, 1. getting too much fuel, or 2. the ignition is inconsistent.
Discussion Starter · #27 ·
Be great to hear more about the angle, thanks. Yes I know the Search you mentioned it :)
I dont know how to adjust.
The point is, that with a Chinese carb, no-one knows how to adjust – they’re all different – different jet sizes – different jet fittings – it’s one big unholy mess
My advice is to let the mech deal with it, or buy the same thing again – rinse and repeat
All you will ever learn from buying a Chinese carb, is that when it doesn’t work, buy another one because they’re cheap and easy
As you may have surmised by now, from a personal view point, I wouldn’t touch them with a barge pole. They have their uses if you’re on a budget, but with the OEM, we know what’s inside, and can fix it with a simple 30 buck re-fit kit. With the Chinese versions, all you can do is buy another one, because no-one is going to be bothered (even if they could) tell you what’s wrong with it. Maybe your mech, carb in hand, can sort it, but from here – no chance
Given the cost of the OEM carb, I would also (personally) suggest a reduction in re-sale price of 300 bucks, simply to reflect what you have on there (or what you are buying into)
I fully realise that this is one mans opinion, but I stand by it. How can you price a TW with a Chinese carb against one with an OEM carb. To those of you that are successfully running the Chinese version, good luck to you, and I mean that, but it’s not for me
One of the main reasons we buy into the whole TW thing, is because of the reliability, and how easy they are to work on. The Chinese carb is so “off plot” it makes a mockery of the whole thing. If the OEM carb was “indecipherable”, prone to failure, we’d be up in arms over the issue
What am I missing here – “I saved 250 bucks in exchange for a potential nightmare, but if it all goes tits up, I can always do it again”
Prefer riding them myself ……
Hello,
I took a look around but most posts are older.
Bought a 87 TW fixer upper and guessing needs carb love. Prev. owner installed cheap car. and prob why runs bad. Would like to take a stab at rebuilding but Bike Bandit says its bad due to that carb and they dont have kits or carbs.
Any advice to where to buy a kit or carb with links please?
FYI - Never rebuilt a carb
thanks
Find someone who can rebuild your carb for your altitude. You can increase the fuel and air. Use a stock air cleaner or better. K& N for a TW-200 is worthless and not better than stock. Drill holes in the airbox where water will not enter and install lovered vent inserts, about one inch diameter.
Discussion Starter · #34 ·
Hello, yes its going to my mechanic on Wednesday to address the Carb issue as well as the starter issue. I have an option to buy a used OEM carb from a member so have that on the table as well. Thanks for the reply and info!
21 - 34 of 34 Posts
