1 - 13 of 13 Posts
While I had the old girl fired up today I had a volt meter on the battery. It never showed anything over battery voltage. Not that I ran it very long. I followed the diagnostic flow chart for charging system diagnosis. Looks to be the regulator/rectifier. As I am trying to keep the costs down until I know it will live I would like to avoid spending over a hundred bucks on a new OE part. So the question is, will the '88 and newer part fit the earlier setup?
I do not have direct knowledge, but looking on line I found three different fitments:
1987
1988-2000
2001 up
Maybe you will better response in the morning
Stator resistance good? Not grounded?
I’ve never owned an 87, so you might want to wait for 87 owners to chime in.
Amazon has a cheapo version that is advertised as 1987 model. They list the same part # as Partzilla. It has a 4 wide connector vs the 2 X 2 connector on 1988+ models. See what connector your bike has. Use caution because the 87s have electrical systems unique to that model year only.
https://www.amazon.com/Electrical-AYA6021-1KH-81960-00-00-2JA-81960-90-00-2JA-81960-A0-00-x/dp/B008CQR8TU/ref=sr_1_1?s=automotive&ie=UTF8&qid=1547484130&vehicle=1987-1210-20056-20-----13941------9-0&sr=1-1&ymm=1987:yamaha:tw200&keywords=regulator
Cheers and good luck. That didn’t take you long to get it running.
Thanks guys. I know the 87 has a different electrical system. That's where the questions come in. According to the manual and my meter the stator passes inspection. I've seen a couple different units advertised for the 87 and up. But not sure I can trust that because of the different stator. Was hoping someone with more knowledge on the subject that I would have an answer. Still looking around trying to find an answer.
I think BadgerFlorida covered it.
1987 has a smaller unit, appears to be different mount and has a different connector.
Looking on-line, most have photos to compare.
Based on this, an 87 is the choice.
If you were to bypass the connector and mounting differences, the internals are likely different.
I would not want to chance frying a stator or burning out bulbs.
You many still get a forum member with an 87 for more insight, so that is just my logic for now
I have an '87, but don't know the answer. Sorry.
Does yours look like this?
Or does it look like this (1988-2000)
Or does it look like this (2001 up)?
Well, it appears to have four spade blades in parallel, but the width of the 7 cooling fins may differ.
Looks the same as the one in this thread, although a photo from the connector end of yours should assist verifying.
https://www.tw200forum.com/forum/technical-help/61138-1987-tw200-voltage-regulator-wiring-help.html
It certainly is not compatible with 1988-2000, nor 2001 to current.
Therefore you have at least three options:
1. Purchase an aftermarket from ebay/Amazon for about $30
https://www.ebay.com/i/362034293612?chn=ps
2. Purchase a genuine Yamaha part from Partzilla for $111.29
https://www.partzilla.com/product/yamaha/1KH-81960-00-00
3. Purchase one from a dealer for $168.99 1KH-81960-00-00 superseded by 2JA-81960-A0-00
The four spade connectors all in a row do not match what I have. It is two rows of two on mine. Like shown on the later models. I'm thinking the '88 and up version is worth a try.
Look at the actual label on the headstock for the manufacturing year. Sometimes the titles are wrong.
1 - 13 of 13 Posts
