1 - 3 of 3 Posts
Hey guys so I bought a 1987 Tw200 and I've hit a wall. First I know my regulator rectifier is bad, and second I can't get any of my indicators to work. My hi and low front beams work and so does my back running light. If someone could show me the part number or a link to a relay that would be great. I would also like to throw out that my battery since it hasn't been charging is at 5 volts and my electric start doesn't work and none of my dash lights do either. If anyone knows if these are all related to a bad CDI or relay that would be a huge help and so would any photos. Kick starter does work quite fine.
Always start with the battery in troubleshooting. Take it out and try to charge it and then have it load tested first. Start there. :D
And...Welcome to the forum!!
When I first got my 87, I had to replace the battery, take the grips apart and clean all of the switches , rebuild the carb, rebuild the gas tank, recover the seat and repair solder joints inside the CDI to get everything running right.
1 - 3 of 3 Posts
