So we have tried two rectifiers for the 87tw the last one fried.question is how do I find out the correct pin out on the rectifier? Can't keep buying rectifiers hoping it's the right one.Any suggestions?? We have lots of voltage out of the stator and it runs fine but won't charge,has to be the rectifier.Any help would be great.
Welcome. I think you stumped everyone on blowing rectifiers. I would start at the left hand stator cover and check for pinched wires if you had that cover off at any time. I suspect there is something shorting out and blowing the rectifiers from the charging system. Maybe a crossed wire somewhere.
The output of the rectifier (red wire) runs through a connector, main fuse, another connector and to the battery. Are you sure the fuse is good? Connectors?
Related Threads
TW200 Forum
532.4K posts
23.4K members
Since 2010
