My 2003 TW200 starts and runs well, and the engine turns off by a twist of the key. However, toggling the kill switch (right handle) does not kill the engine. With the key in place, the ignition button will turn the engine over even if the kill switch is set to not run. I disassembled the switch assembly and cleaned it, but no dice. The wires don’t appear to be cracked or exposed anywhere.
I’m thinking that the RH kill switch may not be the source of the problem, however. The side stand switch also does not kill the engine. So, I can ride in gear with the stand lowered, which isn’t the best idea. The side stand switch wires appear to be in good condition but the switch won’t do anything - doesn’t make a difference if it’s even plugged in at the connection under the seat…
I’d like to get my kill switches working again but I’m having a hard time finding any way to do that. What could be causing both of them to malfunction?
Any ideas/suggestions of where to look next would be awesome. I can post a copy of the wiring diagram I’ve been referencing, if that helps. Thanks in advance!!!
