1 - 6 of 6 Posts
So I had been reading (here) that the XT350 tank is an option for larger fuel capacity.
After searching regularly for several months I saw one come up on eBay for $125 + shipping ($25).
It was rust free and looked like this when received... (no gas cap)
Initially I wasn't concerned about the few little dings it had but as I looked at it on my table I decided to maybe touch it up here and there.
Let's start with the decals...
Maybe touch up that ding. Gotta get it to metal first though. Right?
OK, so I guess I may as well strip the entire tank. By hand. Then bondo.
I was planning to use the TW in Death Valley end of March so time was running out.
I wouldn't be able to do the painting myself.
At this point I was getting frantic and was just gonna spray it with truck bed liner.
Discussion Starter #2 (Edited)
After discussing my dilemma with a co-worker a plan was established.
I handed the tank over to a co-workers painting instructor who applied the primer, base and clear in urethane.
Came out pretty nice.
Here's how it was set up after my return from DV...
3.2 gallons in the XT tank and another gallon in the rotopak... range!
Only the slightest wrinkle in the seat fabric from the bend for the larger tank.
I did clip some of the under seat plastic pieces but they key was using my heat gun to heat and bend the seat pan to the angle I needed.
I did make the extended bracket for the longer XT tank just like mentioned in the XT350 tank install thread here on the forum.
I'm hoping for a range of near 200 miles. (w/o rotopax)
Time (in the saddle) will tell.
edit to add...
I did have to add Zeta bar risers to allow the bars to go lock to lock w/o hitting the tank.
1 - 6 of 6 Posts
