1 - 20 of 38 Posts
Note: I have updated my policy to only ship domestically (United States). Sorry for any inconvenience.
EDIT: The frame will not be available until about 6 to 8 months from now, sorry. Also please note that at this time PayPal is the only form of payment that I am accepting (Cash in the mail is OK for items selling for $20 or less).
Below is a list of everything I have left (as parts sell, I will put "SOLD" to the LEFT of the number of that item. Message me here and/or send me a PM if you're interested in any of this stuff, or know anyone who is. Or if you have any questions about any of it...Thanks!
1.)frame (current title would be included - just like when selling a complete vehicle; however, I won't be able to sell this until after I finish paying the remainder of the motorcycle loan balance for this vehicle)
2.) Complete bottom end (of motor) - stator may be bad? - motor was running perfectly when I started parting out, except that after a few minutes it would randomly cut out and die - I believe now that this may have been due to a bad stator (I didn't actually test the stator)
**SOLD**3.) cylinder, piston/rings
**NOT REMOVING FROM MOTOR - ONLY AVAILABLE as part of the bottom end**4.) cam chain (only a couple thousand miles on it - since top end rebuild) and cam chain tensioner
5.) two CDI's
6.) two regulators/rectifiers
**SOLD**7.) front forks (bad oil seal on left fork/ damaged fork boots)
8.) headlight and mounting hadrware+mounting bracket (bracket is bent so headlight aim is off, but it's useable and could probably be straightened out a bit)
**SOLD**9.) speedometer assembly in kilometers per hour (in good shape but the box/braket that the speedo box mounts into is broken - but it still mounts fine and is totally useable); indicator light box (mounting points are broken but it is useable if you tie it down to the mounting box/bracket that it sits in, with a couple zip ties [I used it that way for a few thousand miles without any issues - it didn't fall off or anything])
10.) rear tire with about 50% tread life remaining with good tube, front tire with about 10% tread life remaining also with good tube
11.) good, straight, clean rear sub-frame
**SOLD**12.) horn
13.) rear shock
**SOLD**14.) ignition coil
**SOLD**15.) stock (OEM) handlebars
16.) brake and clutch levers; front brake master cylinder and brake hose (these two parts are from a 1997 Suzuki DR200, but I used them on my TW for a few thousand miles with no issues); front brake caliper and pads (with about 40 percent pad life remaining); front brake rotor(disc) with mounting bolts
17.) all handlebar switch gear in great shape (kill switch, starter button, horn button, etc.)
18.) shift lever, rear brake lever with complete rear brake lever "pull bar" (including springs, wing nut, etc.), operator foot pegs (left one is bent down/lower to the ground, but useable if you don't mind that, or if you think it could be bent back...), passenger foot pegs and mounts (pegs are scraped bute totally useable, mounts aren't bent)
19.) exhaust pipe (actual pipe only, no muffler)
20.) 44 tooth rear sprocket
**SOLD**21.) rear drum brake assembly including brake shoes (with roughly 20 percent life remaining @ 15k miles)
22.) throttle cable with handlebar-mounted cable housing
23.) rear fender (scrapes and small holes - mostly on one side, but useable and not too bad looking)
24.) front wheel fender (a few minor scratches but looks good)
25.) front headlight fairing (scraped/cut, in rough shape, but useable)
26.) side cover plastics (in good shape)
**SOLD**27.) front turn signals (with only minor scratches), rear turn signals (plastic slightly broken around the edge where the lens cover mounts to the bulb housing, but totally useable and not too rough looking) - bulbs included with all four turn signals
**SOLD**28.) side stand with mounting hardware and safety/kill switch (can be sold individually or all together)
**SOLD**29.) plastic box that CDI mounts into and the rubber strap that holds the CDI in it
**SOLD**30.) air box and air filter
31.) clutch cable
**SOLD**32.) rear brake light/license plate mounting bracket and brake light assembly (bulb not included)
33.) miscellaneous electrical wiring/cables, nuts/bolts, etc.
**SOLD**34.)"www.cycleracks.com" rear luggage rack (some scrapes on one side but otherwise in good shape)
**SOLD**35.) Complete carburetor assembly
PM sent.
i need a title with vin sticker (if required I will take the frame but really do not need it
rear cycle rack if available depending on price
emillio
340 201 3341
3.) cylinder, piston/rings (slight overbore due to top end rebuild a few thousand miles ago) - again engine was running great
5.) two CDI's
12.) horn
13.) rear shock
14.) ignition coil
19.) exhaust pipe (outlet pipe only, no muffler)
20.) drive chain and sprockets with mounting bolts/nuts/washers included (chain and sprockets a bit rough, but useable)
31.) clutch cable and crankcase clutch lever arm with return spring
34.) "www.cycleracks.com" rear luggage rack (some crapes on one side but otherwise in good shape)
I shouldn't have listed the frame/title yet, as I haven't yet paid off the loan balance. I didn't think it through, sorry about this.
FYI, I bought a muffler and rear rack from KJ, he is a good guy to do business with.
Rick
EDIT: The frame will not be available until about 6 to 8 months from now, sorry. Also please note that at this time PayPal is the only form of payment that I am accepting.
5.) two CDI's
12.) horn
13.) rear shock
14.) ignition coil
Discussion Starter #12
Rick
The same can be said of Rick. Good deal and thanks!
Discussion Starter #13
The rear rack is sold.
Discussion Starter #14
NOTE: I realized that my list did not contain the carburetor. I do still have the complete carb for sale. I have now added it to my list.
Discussion Starter #15
UPDATE: I have just updated the list to reflect items on it that have sold. Many parts still available (see list)!
PM sent re forks.
1 - 20 of 38 Posts
