1 - 4 of 4 Posts
Just bought this TW200. 340lb. rider. Upsized the rear sprocket to 55. Warm engine, Feathering the clutch while trail riding causes a loud chatter with shudder and slipping under partial engagement while moving ahead from a stop or low speed. Thought it might be wrong oil used by previous owner. Drained oil looked clean, not burnt. Refilled with silkolene pro 4 10w40. Havent had a chance to try it. Return spring OK and adjusted. Basically shudders at engagement.
Just seemed odd. No sign or sound of chatter prior to todays slow tight woods shakedown ride. I was only into it maybe 1/2 hr when engagement noise began. Only 3100 miles on odom. no noise after cool down as far as I can tell. Might just have to face the music and do a clutch. Is there a clutch suited better to heavier loads than the OEM Yamaha??
1 - 4 of 4 Posts
