Old/new bike, 130 miles so far, bought it new last month. The clutch is now engaging almost at the end of the handle movement - you have to let out the handle almost to the end and occasionally it just slips the clutch at that point. This is a new thing, it was not doing it last time I rode. What is happening, any ideas?
Have you tried the cable adjustment on the lever?
New bike. Cables stretch initially, so run through the adjustment procedure. You may need to do a couple of adjustments within the first few hundred miles.
Lube your clutch and throttle cables and make sure your clutch arm return spring was installed correctly while you're at it.
