1 - 9 of 9 Posts
Seems my owner's manual failed to include that. Time for the 1000 km. service. Can anyone provide?
As always, appreciated,
Toad
Couple of questions. Did the first oil change and found a pretty good buildup of filings on the filter. Is this normal?
And looking at the valve covers I can see I can remove them without taking everything apart. And hopefully do the valve adjustment. Anybody done this?
Yes and yes.
Don't worry about the metal filings in the filter - perfectly normal for the first 1000 miles - (although if you find as much next time, I'd be concerned). Just change the oil and enjoy the ride ......
I remove my fuel tank and carb.when i do the valves. Takes a while longer removing everything, but waaay more clearance for my big mitts to get in there.
Completed my service. Found the spk plug and valve settings on a sticker on the chain side swing arm. Removed the seat and tank as it was easy peasy. The chain had stretched a good amount. Lots of play. Moving the adjusting cams one notch almost seemed to tighten it too far. But after a ride it seems just right. ;)
1 - 9 of 9 Posts
