Three years ago my TW got a XT350 steel fuel tank of about 3 gallon.
That’s fine for the everyday ride, but now I got aspirations to do a big ride as soon as I get my pension and will be free of the everyday grind of a job.
Last week I stumbled upon an Acerbis tank for a Yamaha TT 600, made in 1989 and never used.
The TT600 was never introduced in this country, so the shop finally put a reduced price on it.
I took it home for $50.- and it looked like it could be made to fit.
Today I put it on and it looks like I need to make some brackets and that’s it, fits just fine and should hold 20 liter or 5 gallon.
It came without the 2 petcocks and tank cap.
Does not look so bad
It is sitting a bit higher than the old tank
The seat is in its normal position, the small hole in the tank just above the front of the seat has a threaded nut in it. The seat was shortened to fit the XT350 tank. Now I may have to lengthen it to fit the TT tank
I may put another riser under the handlebar that is here turned all the way to the left
The 2 holes in the bottom have threaded nuts in them, I put a rag on top of the frame tube to keep the tank in the right position
The front fork tubes and triple tree are just not touching the tank
That’s what the bottom looks like
