I just put my 2nd Yuasa to rest since 2009. I'm not having very good luck with them. Checked the water often and kept on a battery tender jr..
I just shelled out over $135.00 for a new Shorai battery LFX14L2-BS12 . So far I love it. It better live up to the hype
!!! If it fails the first thing I do will be to post it here.
I have read tons of good reviews on several sport bike forums about them so I have high hopes.
Specifications Voltage (V): 12
A/Hr PbEq: 14 (See Bottom Of Page)
Cranking CCA (A): 210
Weight 1.6 Pounds
Max Charge (A): 14
The last great battery threads
http://tw200forum.co...battery-survey/ (Sorry Qwerty)
http://tw200forum.co...1/ShowPost.aspx
Q. How does the LFX "PBeq AHr" capacity rating compare to lead-acid Ahr ratings?
A. First, we need to understand that the primary job of a starter battery is to flow a large current (amperage) for a short time, in order to start a vehicle. In order to do that efficiently, the battery must have low internal resistance. Holding all other considerations equal, the larger the battery is in capacity the lower the resistance, and the better able it is to crank a vehicle under high loads.
Lead-acid makers have therefore used AHr(capacity) ratings as shorthand to indicate cranking ability, rather than a real usable capacity. The lead-acid capacity rating itself is based on a complete discharge at a low discharge rate. Under actual cranking conditions they will deliver considerably less than spec capacity. And because lead-acid batteries begin sulfating when only a small percentage of the capacity has been used, and their internal resistance rises as they are discharged, the actual capacity which can be USED may be as little as 20% of the mfg. rating. Discharge in excess will not only damage the lead-acid battery, it may not allow proper starting as voltage sags.
Shorai LFX are based on a completely different chemistry. Not only do they have less than 1/3 the internal resistance per capacity than do lead-acid, they are also the ultimate "deep-cycle" battery. The internal "completely discharged" capacity of a Shorai LFX is 1/3 the rated "PBeq" capacity. For example, the LFX18 12V series have 6Ah cells internally. But the cells are capable of 80% discharge without damage and while retaining more cranking ability. As such, the USABLE capacity(or "reserve capacity") of an LFX18 12V battery is on or very near par with 18AHr-rated lead acid batteries, while providing superior cranking performance and a vast reduction in weight. The Shorai PBeq AHr (lead-acid equivalent) rating system therefore allows users to compare a very different technology from lead-acid, but on a close apples-to-apples basis when making a choice.
Q. How does the LFX "CCA" cold-cranking rating compare to lead-acid Ahr ratings?
A.CCA ratings another way that lead-acid makers have tried to convey starting power. Unfortunately, their typical spec is based on a "half-nominal-voltage" delivery. That is, at their CCA spec, you can expect 7.2V delivered, at best; and 7.2V isn't useful, as you won't start a vehicle with it...
In any case, CCA ratings aren't about actually drawing that much current from a battery. The typical vehicle which uses a 200A CCA-rated battery, for example, will only draw 45A~80A from the battery. What the CCA rating really intends to convey is how much voltage will be delivered. Higher CCA rated batteries will deliver more voltage at the same actual cranking current. Our LFX are CCA rated to deliver 9V for a 5-second crank at the CCA rated current. (in fact, our average voltage delivered will be even higher during a 30-second crank. But our CCA ratings are intended to indicate not only a measure of voltage at true cranking currents, but also proper usage, which lead-acid do not) At actual cranking currents - which are always well below CCA, LFX deliver up to two volts more than an equivalent-CCA-rated lead acid battery. Current alone won't start anything. It is the current multiplied by voltage that does the work (watts). In reality, this means that you can multiply the LFX CCA rating by 1.5x to compare to a Lead Acid battery CCA. For example, our 270A CCA LFX18 series provides about the same cranking voltage as a 405A-CCA-rated lead acid battery (from a quality lead-acid maker; some CCA specs we've tested on the cheapest lead acid seemed to be plucked from thin air).
