1 - 4 of 4 Posts
After taking a tiny spill yesterday, I snapped off half of my brake control lever. So I started looking for an aftermarket replacement and found these:
http://www.sixsixone.com/v1-mdx.aspx
http://asvinventions.com/Unbreakable-Levers
Has anyone experimented with these? Has anyone used any other brand of "Unbreakable" contol levers on their T-Dub? Sunline only makes levers for the following Yamaha motorcycles: (What would be the best fit?)
YZ 85 (02-11)
YZ 125 (01-07)
YZ 250 (01-07)
YZ 250F (01-06)
WR 250F (01-05)
YZ 426 (01-02)
WR 426 (01-02)
YZ 450F (03-07)
WR 450F (03-05)
Thanks for your thoughts and inputs!
Watch out for some aftermarket dirtbike levers. They often don't have the little cam gizmo that actuates the brake light and clutch safety switches, nor do they have a means of adding a switch.
Nothing worse than buying high rent adjustable levers and finding out you've lost your brake lights.
A lot of the stock type YZ direct replacement levers will fit our perches, but again make sure they have the switch engagement cams.
A set of decent hand guards solves the broken lever problem permanently and for a lot less munny.
Just sayin'.
1 - 4 of 4 Posts
