I was looking at a TW carb diagram online OEM Parts (rockymountainatvmc.com) and I see that the diagram shows an air screw at the bottom of the bowl #27 on the diagram. It also shows the pilot screw #16 and plug #32.
I read posts on this site and folks are talking about air / mixture adjustments 1.5 to 2.5 turns out. I assume they are referring to the pilot screw. Because many times they mention taking the plug out first which is only a pilot screw issue. Is my assumption correct?
And, are there adjustments for the air screw #27? Mine is screwed all the way in. I think I did this thinking it was a float bowl drain screw.
Thanks!
Thanks!
