1 - 8 of 8 Posts
Ordered roller bearings from Procycle.
Procycle closed, bike apart, need to get it back together.
Just put the top race in, it protrudes, +1/16 in. 3/32, above the flat top where is it inserted into.
Due it being a roller bearing, is this normal?
Thank you
Don't worry about it, they are all like that.
Reactions: Ken
Crank it down - it'll be fine .....
Hummph, don't know if i trust y'all or not then :)
If it breaks, i'll bring it to y'all to fix.
Thanks.
as a fill to another thread i posted, the bottom race was in bad shape, top not so bad, but still slight dimpling.
I think that most people do not realize how minute of a dimple in a bearing affects it.
Yes, the All-Balls replacement steering head bearings do protrude more than the stock ones.
To make sure that they fully pressed in, you can use some flat washers and a large C-clamp or a welding clamp like this one from Harbor Freight (they are offering 25% off coupons this weekend!).
https://www.harborfreight.com/
next time i'll use a c-clamp.
I know they are seated from sound.
as note i did not damage the race, nor bearings putting them in and they are fully seated.
I sure thank y'all for the info.
Need to get it back together and have a look at the wheel bearings.
Didnt realize HF had a sale going on.
went there this morning to get that 8x.xx bike jact.
only cost me 70$. that was good there.
Finished finally. Put a tarp down to catch anything i dropped. didnt work too well.
miss the head bracket bolt and the insert for the rubber side of the headlight mount.
Headed outside with crown n coke.
I dont drink. but.... i deserve this one.
1 - 8 of 8 Posts
