Hi Everyone,
I thought I would show a couple quick pics here. I just picked up this Tdub last week and have been slowly and carefully evaluating it.
I got it from a kid that was going off to school and needed it out of mom and dads garage. He hadnt owned it very long and I suspect he was the one that caused the problem I will show here.
I got it with the understanding that it didnt run. I looked it over and it wasnt locked up. pretty rough and I immediately noticed that the kick starter wasnt engaging. I took a look at the rust in the tank and decided to make an offer on the suspicion that there were fuel problems at least. I ended up taking it home.
Once home, I gave it a squirt of ether and it fired. Sounded like crap though. Noisy valves at least. I decided to head out to pick up some oil to start fresh on.
Bad News, shrapnel in the oil filter. Clutch? hmmm... unlikely. Another bad sign, the oil pump inlet screen and retainer spring were missing.
Finished the oil change, set the valve clearance, and fired it up. The next omen was that i didnt get any oil pressure at all from the oil bleeder screw on the head. Shut it down quick...
Upon cracking the case, I discovered that the Kick start components had been stacked incorrectly and parts were missing. I also noticed that a lip from the actual inner housing of the case was broken off and missing as if someone had CRANKED THE KICK START SO HARD THAT THEY BROKE OFF THE STOP FLANGE!
I pulled the clutch gear and next pulled the oil pump.
How bout that... the oil pump housing was shattered. I decided to dissect it and see what caused the heart attack. Sure enough, I found part of a missing "c" clip from the kickstart assembly. I'm still missing stuff but i'm going to clean it out well.
Anyway... I feel like I'm making good progress.
Anyone know if the broken stop flange next to the kick start shaft is going to be a problem. I suppose I could press in a pin to replace it if I need too... Thought?
