Hey everyone,after changing my front sprocket back to factory 14T,and yes I replaced the rear one as well.Also while I had it apart I changed both seals and new gasket.I am having a small leak,maybe a drop or two on my garage floor after I ride.No big deal,but I would like to know where it is coming from.It is NOT coming from the new seals,they are both dry.I am pretty sure I got most of the old gasket off,my only other thought, would it be coming from where the small rubber grommets go through the case cover? There are no pinched wires.Does anyone put a small bit of silicone around the grommets before they put on the new gasket? Anyone else have this problem?
