1 - 8 of 8 Posts
I am as smart as a rock when it comes to math. I'm the guy getting yelled at on the job site for "I've cut it twice and its still too short!"...
I just purchased a new tool chest and top box and would like to line the drawers with some industrial rubber that I found at OSH.
Its purchased on a roll that is 24 inches wide.
The measurements I need are as follows:
(5) pieces @ 22 1/4 x 16 1/2
(9) pieces @ 22 1/4 x 10 5/8
(2) pieces @ 26 1/4 x 17 3/4
Can anyone out there tell me how many feet to purchase?
Thank you so much for your help.
....and to think, I skipped math to learn to weld in the auto shop LOL
You need 210.25" if you make perfect cuts. If I was ordering it, I would probably buy 215", then I would roll it out and let it sit relaxed for at least 24hours. Then I would make the cuts. BTW, I'm not truly a contractor, but I play like I am somtimes and I once spent a night in a Holiday Inn.
On edit, I see you asked for the measurement to be in feet. Buy 18 feet.
Oops! I forgot to turn the last one sideways. The other guys are correct! 20 feet! Hanging head in shame
Because your last two pieces are wider than the roll you will need more. You will need 82.5" for the first 5 pieces, 92 5/8" for the second 9 pieces, 52.5" for the last two if you turn you sheet 90 degrees to get a full draw width.
You will need a total of 19.21875 or 20 feet to be realistic.
Lucky I had a calculator to hand.
I have a second on 19.21 (or 20 for a round, let's you be less than perfect number) feet.
Plan B
The rubber carpet runner didn't work out (would have cost $100) Yikes!
I've now found some "Golds Gym Equipment Mat's" at walmart for $19 dollars.
They measure 36x78.
How many "mats" would I have to buy to have enough to cut (9) 22 1/4 x 10 1/2 pieces?
and (5) 22 1/4 X 16 1/4 pieces?
Sorry for making you figure this out twice!
Thanks
You could do it with 3, but you would end up with a lot of waste.
Still cheaper though.
A big thanks sent over to your side of the pond from someone who still uses spanners, not wrenches.
And yes, I've got an imperial set too LOL
1 - 8 of 8 Posts
