yea, I know its possible, I was more hoping for tips tricks from those skilled at it on this specific bike
anyone who has experience I can draw upon would be greatly appreciated.
Well it takes some balls and guts to do it
. cuz you will at least drop your bike once or twice or maybe more it depends on how often you do it (practice), but as I say it takes some balls. My suggestion try it on dirt or grass (but not when you have street tires on it-it's harder) cuz when you fall on dirt and grass which is softer than asphalt or concrete it will help absorb the impact meaning less damage to the bike and yourself. According to my experience when I learned how to wheelie (when I was a teenager - never went to stunt school) I started with both feet on the ground to help me balance the bike and then started to rev the bike a little high while holding the clutch then let go, but you wanna keep your left hand on the clutch to control the power (you dont wanna over rev it). try it until you get your front tire above ground like 1 ft, then try 2 ft, then try it higher and higher (play with the rev while the bike is moving so you dont fall backward).
Once you able to do it with feet dragging on the ground now try it with feet on the pegs which is harder cuz you need to balance the bike with your arms and body. GOOD LUCK!
I'm just sharing my experience. I'm not a pro stunt rider or something, but hey it worked to me!
maybe someone else here has better methods or technique? Please help sakogu...
cheers
