I recently ran across a new (to me) way to attack the problem of tires that are hard to seat on the bead.
In my case it is mounting a car tire on a motorcycle rim. Don't start on me... I've done it before. It works.
So a car tire has a different bead profile than a motorcycle rim. Just like the problem of mounting an ATV tire on a TW rim.
This all leads to the rear wheel on my Yamaha Royal Star. I found the right car tire and had my favorite local dirt bike shop mount it up.
I am not a fan of superoverpressurizing a tire to seat the bead. I've known two good men who were killed mounting split rim tires and it makes me queezy about waiting for the pop. I asked them to leave it at 75 psi overnight.
I picked it up and neither bead had popped. I set it behind the propane pretend wood stove after airing it up to 90 psi. No pop after two days.
I broke the bead, spun the tire, lubed it up, and re-aired it to 90 psi. After two days, nothing. I repeated it again for two days.
I took it back to the bike shop and asked them to dismount it so I could grind the ramp of the aluminum wheel for an easier bead seat.
I know, aluminum wheel. Stay with me for the money shot.
The owner of the shop, a man I had never dealt with, said he could seat the bead without messing with the wheel. So he went over to his Coats Tire Machine,
COATS RC-45A RIM CLAMP TIRE CHANGER ( AIR).
He put the car tire on the machine and used the rim clamps to stretch the bead of the tire. This makes more sense to a tire guy.
He stretched a bit, loosened, turned the tire, stretched a bit, turned the tire, etc.
Then he did the same to the other bead, mounted the tire, and both beads popped with less than 60 lbs.
This whole operation spooked me. I am an old tire guy and I had never seen anything like this. He said he's been doing it for years and never had a failure.
I am 1,500 miles into this adventure and have not had a failure. I feel confident that this car tire will go 60,000 miles or more with no bead troubles.
I think if I had an ATV tire and worried about how it would bead up, I'd want to consider this way of loosening up the bead of the tire.
Yes, we are playing with the most important part of a tire, the bead. It is nothing to mess with. Personally, I would never grind a bead on a tire...but I'd try this.
