So I FINALLY receive the parts I need to repair my pony...you may or may not recall that the SOURCE COIL on my ignition system fried itself two weeks ago, just before a big group ride.
Dealer had no part in stock, so it had to be ordered from Japan, and it arrived yesterday after what seemed like an eternity.
Here is a pictorial as to how it went back together. If I can do it....anybody can!
...and before ANYBODY asks if I was CERTAIN that the problem was the source coil...I'll say it again: YES! I measured the resistance at points A & B as shown...
New coil (on the left) = 700 ohms
Old coil (on the right) = 1,200,000 ohms.
Everything goes back into the same location it came from. This is what it should look like when the Stator and Pulse coils are remounted. Note the brackets that keep the wires out of harm's way. I highlighted the bolt that broke off in the case...and it didn't even have to be removed!!!!
While I wait for the loctite to set up, I move onto other points...
Here is a look at where everything goes...as well as the NEW front sprocket. When you change sprockets, make sure that you clean all the gunk, dirt and assorted crud from around the output shaft.
A look at the whole thing, including the NEW rear sprocket! I went with a 14/47 combination this time. A 6% gain in top speed, but a 6% loss of bottom-end torque as well!
NEW O-ring chain installed too. Note the direction of the Master-link clip.
About 124 links gets it to mid-stroke on the adjusters...should be good enough!
A new gasket for the crankcase cover...I smear a light coating of synthetic grease along the mating surfaces; that way, if I have to split the case in the near future (heaven forbid I messed anything up!) the gasket won't get ruined and I will probably be able to reuse it.
Just in case though...I already traced this one out on gasket-stock!
Before, re-assembling, I use some compressed air to blow out all the crud from inside the engine. She's been apart for two weeks now, so I won't take any chances.
Once reassembled, it should look like this!
Torque down all the bolts in a criss-cross pattern to avoid warping the cover. Now, I fill the engine with oil and start re-routing the cables and re-connecting all the wiring. The battery has been on a trickle charge all night, so she should be fully charged by now.
Before replacing the fuel tank, I test the ignition system for spark. Much to my chagrin, I can see none!
Was this all for nothing? Now I'm starting to get pissed!
I do a couple of other tests, try a few different plugs, wiggle some more wires...nothing. So I get right down near the engine and have a close look...well waddaya know...it IS sparking...but strangely!
There is a nice, clear spark when I first turn her over, and when I stop...but nothing in between. WTF???
Thinking that this might be enough to get her going, I replace the fuel tank and fill her with some nice 90 octane. I crank and crank and crank but nothing doing...
I can tell that she is TRYING to fire, because she turns over faster when I twist the throttle, and slower when I release it...so SOMETHING is going on...
After 15 or 20 minutes, she eventually "catches" and sputters to life. While she is running, I check around for leaks, drips, or funny smells...the rectifier seems warmer than it should be...I can touch it, but I can't leave my hand on it for too long. I assume this is because of all the cranking I did and the drain on the battery.
I let her warm up for quite a while before shutting her down to drain the oil; just in case I didn't get ALL the crud out with the compressed air!
With fresh oil and a clean filter, I try her again...still a bit tough to start, but she catches within a few seconds. I let her warm up completely before taking her for a test-drive. The new sprocket combo is nice on the street, we'll see how it works out in the bush.
Everything SEEMS to be OK so far, although I am concerned about the whole spark thing and why it took so long to get her started again. I know that these bikes NEED TO be started at least once a week...but I don't understand WHY this is.
Hope this is helpful...
