Hello, been on this site for some time, mostly looking (lost my log in?), but been here since 2005.
I need HELP!
I have a 2005 TW, ~1300 miles, bought it new. Put on about 600 miles this summer.
Riding home from work, 15 mile into a 20 mile ride at ~55 mph, the bike starts to vibrate BAD. Thinking the tires are chunking and coming apart I pull in the clutch. Vibration goes away, tires look good, .... In trafic I let out the clutch and accelerate (with excessive vibration) till I can pull off. Stop bike and it idles fine. no smoke, oil in the window,... revs fine. Get back on to go home and the vibration goes from nothing, to bad at mid rpm, to minimal/normal at higher rpm. Power seems the same. accelerate up to 70 mph with minimal vib. Hummm.
Testing at home the vibration occurs in all gears at mid rpm. OK at low, power is good, then as rpm's build the vib is bad, then seems to smooth out. This happens in ALL gears. This happens with clutch pulled in regardless of gear or not.
changed oil, normal. no metal, bronze, chunks, ... Filter is clean (normal few small pieces). Tires look good, don't wiggle side to side. Chain is tight enough. wheels spin fine.
opened left side engine cover, flywheel looks right and hasn't appeared to have shifted. Timing looks ok, but not perfect, maybe 1/4 to 1/2 tooth off?? Again, doesn't surprise me. Opened cam and front rocker covers: timing chain is rather tight, no way it jumped a tooth. rocker arm looks good but didn't check gap. No metal shavings or anything indicating the come aparts.
Idea's??
Nic
I need HELP!
Idea's??
Nic
