1 - 8 of 8 Posts
I am going to replace the leaking base gasket on my 2006 TW200 soon. I have read and watched the videos on doing this. My question is why take the wrist pin out and remove the piston with the cylinder? The new base gasket should fit over the piston. I would think it would be a good time to inspect the piston and rings (Old two stroke rider ?)? I have all the parts but I didn’t purchase the wrist pin clips. I also have the piston ring install tool.
I think it has do do with the way the rings are worn in to the cylinder walls. Once you remove them, they won't go back the same way, and they'll have to "break in" all over again (if they even can). At that point, you might as well just replace the rings, and hone the cylinder.
You can re-use the wrist pin clips, if you don't bend them or lose them when you take them (only one side, actually) out. A dental pick is helpful during this operation. An extra set of hands would also be helpful, but it's do-able alone.
Also, if you do remove the piston from the cylinder, you don't really need a ring compressor to re-install it. The bottom edge of the cylinder is beveled, and it's pretty easy to squeeze the rings enough with your fingers to get them to slide in the cylinder. Installing rings on the piston can be done by hand as well.
Have fun! :)
EDIT: My bad, I thought you said you did not have the tool.
I don't know if you're aware of the issue with the base gasket oil leak due to unevenly machined engine halves - if not, you may want to check the respective threads. I solved this leak on my bike by sanding the surface slightly at the problematic area (closer to the front of the bike, I was able to feel the "step" with my finger).
I did the disassembly as per the mentioned video, by removing the wrist pin. It was quite worn, I had to replace it. Could not procure one for the TW, so had to use the same 16mm from a Daewoo Matiz and cutting it to length.
I just pulled the cylinder off the piston and replaced my base gasket. I had the cylinder checked and it was in spec. I didn't want to wear it out any so I did nothing. I stuck it all back together. I rode it around and no issues. I am still riding strong with no piston or ring replacement.
Try re torquing the head bolts. Remove two at a time, clean and lube them, preferably with case lube if you reload, and torque to spec. I have done this several times and 9 out of 10 times the base gasket leaks is cured. Quick, easy, free. Well worth a try.
There is no problem reusing the rings if it had good compression and does not burn oil. It does not matter if the rings get turned, they rotate slowly as the engine runs so that is not an issue. It is just easier to get the piston out of the way otherwise you may damage the gasket. (unless you have 3 hands)
1 - 8 of 8 Posts
